Widest Rear Tire on Stock 348 Rims? | FerrariChat
Discussion in '348/355' started by T-A Tech, Nov 15, 2007.
  1. T-A Tech
    T-A Tech Rookie
    Sep 16, 2005
    49
    Western Massachusett
    Jim Burke
    I'm due for new tires in the spring. Thinking of replacing the Pirelli Assimetricos with Goodyear Eagle F1 GS-D3's. Has anyone fitted 275 rears (of any make) on the stock 348 9" rear rim?
    Tirerack advises a 9" minimum rim width for 275's so it should work mechanically but I'm concerned visually, especially with 25mm spacers in the rear.
    Did a search and found a lot of info on rear tire sizes for stock 355 rims, but nothing on stock 348.
    Jimbo
  2. Houston348
    Houston348 Formula 3
    Oct 18, 2006
    2,297
    i THINK if you were to go wider than the stock 255 (correct?) the tires would stick out from the fenders making it look a little silly imo
    if im wrong, please let me know haha
  3. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    I was looking at the Kumho site as well and they think a 275 section tire it will fit on a 9" rim. I haven't tried it myself.
  4. Armenhaz
    Armenhaz Karting
    Nov 8, 2005
    232
    Glendale, CA
    Armen
    I have 275's in the back of my car, (Yokahamas). I'll post a rear end view next 1-2 days!
  5. Houston348
    Oct 18, 2006
    2,297
    cool! thanks!
  6. T-A Tech
    T-A Tech Rookie
    Sep 16, 2005
    49
    Jim Burke
    Double Thanks!
    According to the tire data, the difference in tread width between 255 and 275 is 7/10 inch, a little less than 3/8" per side. It doesn't seen like much but pictures tell a 1000 words.
  7. speedy_sam
    Jul 13, 2004
    5,559
    TX
    Sameer
    Did you upgrade the tire yourself or was it done by the previous owner. Any comments on grip, stability, etc with the new rear?
  8. dc348
    dc348 Formula Junior
    May 27, 2006
    386
    Luckily back in HK
    DC
    I've just put some 275 Yokohama's from Tirerack on the back of the 348 on stock rims. It looks heaps better and nothing sticks out.
  9. cmjames63
    cmjames63 Karting
    May 9, 2006
    80
    PNW
    CMJ
    Not very likely that it will stick out much from the face of the rim. What I would be most concerned about is the width----> 275/40 <---- aspect ratio (sidewall) to make sure the tire doesnt have a larger diameter then whats coming off the car. You will probably have to drop to a /45 or a /40 to keep the diameter correct.
    CMJ
  10. FAMILY MAN
    FAMILY MAN Karting
    Nov 24, 2003
    153
    ** I owned a 348 Spider back a few years ago and had 27540x17 Bridgestone Pontenza on the rear. Did really well. The stock 255's aren't wide enough in my book.
    FM
  11. Armenhaz
    Armenhaz Karting
    Nov 8, 2005
    232
    Glendale, CA
    Armen
    #11 Armenhaz, Nov 18, 2007
    OK guys, here are the pics, and sorry for the delay. Sameer, thanks for the tire info from your track day. I'll be going with the Kumo's shortly. To answear your question, my car came with these tires, they were good at the begining, but it has been 5 years since I have had the car, and the tires are probably older then that, so now they do not feel as stable, especially the rears, on long sweeping turns on some of the freeways, and it is more pronounced when the tires are cold. So when I change I'll be going with the stock setup this time, to feel what the car would have felt when it was bone stock.
    Let me know if these pics are ok, if not I can post more.
  12. T-A Tech
    T-A Tech Rookie
    Sep 16, 2005
    49
    Jim Burke
    Thanks Armen - that's exactly what I was looking for. Final question - it looks like you have spacers -are they 25mm?
    Jimbo
  13. Armenhaz
    Armenhaz Karting
    Nov 8, 2005
    232
    Glendale, CA
    Armen
    You are welcome my friend!
    Yes, the spacers are 25mm from Hill Engineering.
    Cool, glad I was of help, have fun!!!
    Armen
  14. speedy_sam
    Jul 13, 2004
    5,559
    TX
    Sameer
    Thanks Armen. I had exactly the same loose feeling in the rear of my car when I had a set of Fuzions on that were a bit old and worn. When I swapped it for new rubber, the rear became stable. I think tires have a 6 year life anyway so your tires are at the sell by date.
    I think I will try out 275 section tires next time. I assume you do not have any rubbing issues as you didnt mention it.
    Compared to a stock 255/45/17 tire:
    ... A 275/40/17 tire is about 1.4% faster than stock
    ... A 265/40/18 tire is about 1.2% faster than stock (std 355 tire)
  15. Armenhaz
    Armenhaz Karting
    Nov 8, 2005
    232
    Glendale, CA
    Armen
    No rubbing at all!
    Were you thinking of keeping the front stock?
  16. speedy_sam
    Jul 13, 2004
    5,559
    TX
    Sameer
    Not sure. I would think a 225/50/17 front and a 275/40/17 rear would be nice. I would get 10 mil more rubber in the front and 20 mil in the rear for better grip and less than .2 lb increase in overall weight per tire.
  17. Houston348
    Oct 18, 2006
    2,297
    with the new 275/40 will there be a noticeable gap between the wheel well and the tire? (coming down from 45's or 50's to 40's seems to be much more lower profile)
  18. speedy_sam
    Jul 13, 2004
    5,559
    TX
    Sameer
    Taking Kumho tires as an example going from 255/45/17 to 275/40/17 will mean that the overall diameter will drop from 26.1" to 25.7" = .4" drop overall. Thus the fender gap will grow by 0.4".
  19. cmjames63
    cmjames63 Karting
    May 9, 2006
    80
    PNW
    CMJ
    Actually, it would be "half" of that, giving you 0.2" difference.
    CMJ
  20. cscott67
    cscott67 Formula Junior
    May 13, 2007
    418
    Milwaukee
    Scott
    My (used) spider came with the 295/35/18s. (If you upgrade to 18s) I don't see why you could not run a 295 as well with spacers, Scott
  21. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    You could probably go 285's on a stock 348 wheel I reckon! :):)
    Just by looking at Armen's pics. ;);)
  22. speedy_sam
    Jul 13, 2004
    5,559
    TX
    Sameer
    I dont think so. I think you need a wider wheel. I believe the max that can go on the 9" rear is 275.
  23. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Bah, never say never!! :D:D
    Give me two spoons and I will make it fit. ;);)
    Seriously though, I have 275's on an 8" rim on my old Ford. I took a wild guess and said that you could go 285's on a 9" rim. :)
    Its only 10mm more tyre on rim 25mm wider. Dont know, whatever I guess. :):)
  24. blackcross
    blackcross Karting
    Jun 23, 2007
    100
    #24 blackcross, Nov 21, 2007
    I think the 275 is a little too wide for the camber and will wear out the inner edge too quickly. I've only put 2000 km on the new tires so can't say for sure. 265s seemed to have a much flatter footprint.
    Using 18" 360 wheels. Picture attached is the 265s
    Hagen
    #14 SS
  25. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ
    14,640
    Juan
    #25 Juan-Manuel Fantango, Nov 22, 2007
