Will 7.5j 15” Cromodora fit on 308 GT4? | FerrariChat
Discussion in '308/328' started by Gavin Rooke, May 11, 2022.
  1. Gavin Rooke
    Gavin Rooke Rookie
    May 26, 2020
    16
    South Africa
    Gavin Rooke
    I’ve been offered a set of 7.5j 15” 5-spoke Cromodora rims (fit the 400i as I understand). I currently have 16” Superformance wheels on my 308 and oroginal 14” cromo’s in storage. Will the 7.5j x 15” fit - or is this is a no-no? Price for the set is apprx £800. Image Unavailable, Please Login
  2. wildcat326
    wildcat326 Formula 3
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    7.5 x 14 was one of the original wheel options, and 308s were given 16s after 1982, so I don't see why either the width or diameter wouldn't work, unless the 400i has a different weird offset. However, if you're already running 16s, why would you want to drop down to 15s?
  3. Gavin Rooke
    Gavin Rooke Rookie
    May 26, 2020
    16
    South Africa
    Gavin Rooke
    Wasn’t aware there was an OEM 16” for the 308? The Superformance 16” look great - but I anticipate values will grow with originality. Were the 15” ever an option for the 308 GT4 perhaps?
  4. Gavin Rooke
    Gavin Rooke Rookie
    May 26, 2020
    16
    South Africa
    Gavin Rooke
    I’ve just been sent a link to a previous discussion on this very topic. All sorted - thanks
    https://www.ferrarichat.com/forum/threads/cromodora-15-rims-on-a-gt4.613114/
  5. wildcat326
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    16” was standard for the GTB/GTS from 83 on.
  6. Steve Magnusson
    26,799
    #6 Steve Magnusson, May 11, 2022
    The data in this thread:
    https://www.ferrarichat.com/forum/threads/modern-ferrari-wheel-offsets.8361
    indicates that 400i wheels have an offset of -5mm while the 308 chassis uses about a +11mm offset wheel = the tire centerlines of the 400i wheels would be shifted 16mm outward when mounted on a 308. Not sure if that's much of a problem -- at the rear it would probably look good (if the tire doesn't rub on the wing). At the front, it's a small steering geometry sin, but people run 15mm spacer often with no complaints.
    One other thing you should look into is 308 wheels actually have two different size mounting bores: a deep 58 mm one to mate with the front hubs, and a shallow 67mm one to fit the rear hubs. Not sure what a 400i has (and don't have cross-section 400i suspension drawings).
  7. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    One other issue for 2022 is the availability of 15 in tires - worth checking before committing
