Some of the nicest carbon fiber steering wheels are for the 360. I know there is a difference in center line to the top radius but other than that, will they bolt on fine?
yes many have used the 360 steering wheel on the 355.. it must be one of the nicest upgrades to the 355 interior..
Image Unavailable, Please Login I installed a 360 wheel on my 355 and was fine until the day I sold it. I removed the 360 wheel before selling the 355. Good Luck!
Just make sure you unhook the battery before you unplug the airbag and have the new one plugged in before you restore power or you will set a code that lights up the airbag light. You have to have something like an SD to reset it if you trip it, a regular code scanner can’t get into the airbag system to clear the code. You should have the power cut when playing with airbags anyway but just something to be aware of.
Yes. Absolutely ... disconnect your battery before you start and make sure your airbag is plugged in before reconnecting battery.
Hey judd10 ... is that the airbag and 360 wheel you got from me years ago? Oh wait, you picked up a 360 CS wheel? Looks great!
Had you tried a quick search...... https://www.ferrarichat.com/forum/threads/360-steering-wheel-upgrade.556146/
