Will Fiorano 355 drilled rotors fit on my Berlinetta? | FerrariChat
Discussion in '456/550/575' started by edmo7, Dec 6, 2004.
  1. edmo7
    edmo7 Formula Junior
    Jul 8, 2004
    280
    Irvine, CA
    Ed
    Does anyone know if the drilled rotors on the 355 Fiorano Edition is the same size as the ones on standard 355's? I have a 1997 355. Thanks!
  2. rossi
    rossi Formula Junior
    Feb 6, 2004
    480
    I don't know if they are the same size, but they should fit, as it was possible to order the drilled brake discs only, without the whole Fiorano package.
  3. cal355
    cal355 Formula Junior
    Jun 16, 2004
    383
    San Francisco
    Cal
    Trywww.stillen.com and look at the Sport Rotors for Ferrari.I have a set of both front and rears with the Metat Matrix pads.Alot better than stock.Rotors are Brembos and look like Challenge rotors.Alot less cost than OEM.
  4. 355fiorano
    355fiorano Formula Junior
    Oct 21, 2003
    782
    London
    Philip
    Yes they are the same diameter, just drilled.
  5. edmo7
    Jul 8, 2004
    280
    Irvine, CA
    Ed
    Are the brembo drilled rotors the exact same thing as the ones direct from Ferrari?
  6. cal355
    Jun 16, 2004
    383
    San Francisco
    Cal
    Brembo supplies Ferrari with OEM for both regular and challenge cars.Drilled rotors for the front look exactly the same.The rears,from Brembo(Stillen),pattern of the holes look different from the OEM that comes on a Fiorano.The holes look alittle bigger.
