Will not fill second Gas Tank | FerrariChat
Discussion in '206/246' started by Hondo, Sep 28, 2025 at 9:35 AM.
  1. Hondo
    Hondo Rookie
    Jan 16, 2022
    27
    Edward Greene
    Need a little help. I have owned my 1974 246 GTS for about a year. It had an engine out rebuild several years back with new replacement fuel lines. My passenger side fuel tank will not fill with fuel. I think it has to be the fuel balancing pipe between the two tanks or a clogged air vent line? The vent line coming off the top of the gas tank is routed back to the fuel filler line. It is a CAVIS clear line as seen in my photo below. Any thoughts would be appreciated!
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. Hondo
    Hondo Rookie
    Jan 16, 2022
    27
    Edward Greene
    I forgot to add this is a left Hand drive Euro Dino 246 GTS
  3. Motob
    Motob Formula 3
    Nov 11, 2003
    2,390
    Frederick, Maryland
    Brian Brown
    The routing of your fuel return hose from the carbs and breather hose from the filler neck to the right side fuel tank are correct. You can look at the factory parts manual to see what the fuel tanks and filler/breather hose routing is supposed to look like.
    Your thoughts of a blocked fuel balance pipe or breather hose causing the R. tank not to fill are pretty much the only possible causes, except for the tank being welded shut. I would try disconnecting the breather hose at the top of the tank and blow through it to check for a blockage. If that's ok, then it is time to check the balance pipe/hoses for blockage.
  4. TTR
    TTR F1 Veteran
    6,058
    Riverside, CA
    Timo
    While I don't have much experience on Dinos, I've encountered similar problem with two Daytonas and on both the culprit was the balance hose having been routed so that it became pinched shut by the LH trunk lid hinge when lid was closed.
    Both still had original, dark green"cavis" hoses, likely installed by the factory (or Scaglietti ?) as both had suffered the symptoms for decades and hoses were almost petrified.
    Once re-fueled full, the gauge would show "full", but even after couple of short drives or just sitting long periods, some or half the fuel would slowly seep into the RH tank and show "1/2" or so at the gauge.
