Wind noise - California 2013 Driver Rear/Front Window seal issue? | FerrariChat
Discussion in 'Technical Q&A' started by Oitbc, May 22, 2021.
  1. Oitbc
    Oitbc Rookie
    Mar 25, 2021
    47
    Phil Thomas
    Hi,
    Above 55mph you can hear wind whistling from behind you and it gets louder as you go faster - you feel like a window hasn't been shut properly. The sound seems to come from behind the drivers head. This is with all windows closed and the roof up.
    Looking over the car when at rest, on the drivers side of my Cali 30, between the front and rear window is a seal (attached to the rear window). It appears to be deformed. I'm not worried from a cosmetic viewpoint just that it may be what is letting the wind in.
    Is it possible to heat this up to get it to relax and go flat or is it a case of off to the dealer and get them to replace the seal? I suppose I could put tape over it and validate it is what's causing the issue first, but its the only thing I can find that is in the right area.
    I've attached two pics - one from the drivers side showing the seal (red circle shows the deformation) and one from the passengers side.
    Advice appreciated.
