Window Cable Tensioner | FerrariChat
Discussion in '308/328' started by Mike Florio, Jul 21, 2021.
  1. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    #1 Mike Florio, Jul 21, 2021
    The windows in my 1975 308GT4 had become problematical. I cleaned and rebuilt the drive mechanisms (the old grease had the consistency of beeswax), cleaned and lubed the pulleys, sprayed the channels with silicone/teflon dry lube, etc. Still didn’t work well. I replaced the fusebox with one I fabricated using ATO-type fuses. Cleaned up all the connectors, including the ones on the relays. Still not good.
    When I restrung the cable the static tensioner was at the limit of its adjustment and the cable seemed loose in some areas, tight in others. Overall it seemed too loose to me. I researched later 308 models (with Pininfarina bodies), and noticed that they retained the cable mechanism for the windows, but at some point they had added a dynamic, spring-loaded tensioner element. The 348 or Mondial (can’t remember) had an even more elaborate dynamic spring tensioner
    So I cooked up a simple, easy to fabricate and install dynamic spring tensioner. I looked into sourcing a couple of pulleys (sheaves) and only found one place that had a plastic replacement for $47 each. Off to McMaster-Carr, where I found a slightly smaller nylon pulley with an integral bearing for $11 each.
    https://www.mcmaster.com/catalog/126/1613 Item B, 3/32 cable, 1.5” OD. P/N 3434T15
    The mechanism was fabricated out of ¾” x 1/8” aluminum bar stock from the local hardware store and the springs are available here:
    https://www.amazon.com/gp/product/B008RFPA8C/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    Here’s an image of the pieces. Note that they are assembled as mirror images, and the orientation of the pulleys is critical for alignment.
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Did this modification solve the slow-window issue for you?
  3. Mike Florio
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    No, but it stabilizes the cable so it can't slip off of any of the pulleys. I'm waiting for the relay modules I ordered to tackle the electrical issues.
  4. Glassman
    Glassman F1 World Champ
    I'm going to take a guess here but from my experience if the cable is loose you don't have the correct turns of cable on the spool, or the wire is entering and exiting the spool at the wrong area.
    waymar likes this.
  5. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
    Not necessarily. I have seen were the cable has stretched over time due to excessive tension. Or someone has put soo much pressure on the cable trying to eliminate the slack that the tension has broken the pully leaving too much extra cable.
