Window cable too tight by a 1/4"! | FerrariChat
Discussion in '308/328' started by Quasimotor, May 20, 2018.
  1. Quasimotor
    Quasimotor Formula Junior
    Jan 4, 2004
    351
    Yonkers, NY
    George Avgerakis
    Finished rebuilding the window regulator on my 1984 308 QV Euro. Even with the bottom cable going PAST the tensioner pully, I simply can't get the cable to go down around the last pully (lower rear). It's about a 1/4" too short to get over the lip of the pully.
    I tried running the motor all the way one way, then the other to wrap the grooves on the regulator tighter - did't work. I compared the winds to a used identical part, same number of turns - four including both cable ends. I'm tempted to remove a winding, but I'm pretty sure that will make the whole system too loose.
    Anybody have an idea what to do?? The cable was easy to remove when I took the motor out.
    Many thanks in advance...
    Quasi
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I believe I used 3 windings, not 4. Also, dont bottom it out one way or the other - that is the tightest point.
  3. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    629
    Massachusetts
    Joe
    The windings are about 3 2/3. The cable comes off the spool at a very specific place and angle. There are 3 posts that hold the assembly together, and there is one post that is between the cable. Does your cable come off of the spool at the right post?
    Here is a picture of the installed assembly.
  4. 308 milano
    308 milano F1 Veteran
    5,350
    Montana
    Kim
    ^^ this. Did the very same thing with my old 84 GTB, three wraps and you’re good to go.
  5. Squirrelmonkey
    Squirrelmonkey Karting
    Dec 27, 2010
    126
    Manitoba ,Canada
    Tom Thieme
    Quick Question..Is your cable one piece or did you split then rejoin the cable with a ferrule ?
