Window drop / relearn | FerrariChat
Discussion in '456/550/575' started by wiscobadger, Jul 10, 2020.
  1. wiscobadger
    wiscobadger Karting
    Jan 20, 2014
    70
    Wisconsin
    Cory Eastman
    My passenger side window in my 95 456 GT was going up all the way, but not dropping when the door was open.
    I used the key reset found here to get the drop to return: https://www.ferrarichat.com/forum/threads/456-auto-window-drop-door-open.488192/
    However, once the auto drop started working again, the window does not go up as high as it did when the drop was not working.
    I tried resetting the window ECU using this thread: https://www.ferrarichat.com/forum/threads/456-window-ecu-reset.507617/
    However I cannot get the window to go high enough to create a good seal. Again, before trying to reset things via the key in the door or at the window ECU, the window was going high enough to create a decent seal, it just wasn't auto dropping.
    So basically this morning I had a window that was definitely high enough, but not auto dropping and now I have a window that is auto dropping but not high enough (does this sounds like a vintage Ferrari story yet?)
    Is there a sequence to the reset procedures so that the window relearns the upper limit AND the auto drop feature?
  2. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    456enthusiast, F456M and Il Tifoso like this.
