355 - Window help | FerrariChat
355 Window help
Discussion in '348/355' started by montegoblue, Sep 26, 2023.
  1. montegoblue
    montegoblue Formula Junior
    579
    East TN
    Guys,
    As temperatures are getting cooler, decided to put the top back on the GTS ; usually I keep the car with the top off and windows down during summer. After I put the top back on and roll windows up, noticed that the passenger window is "hiccuping"... comes up but not very smoothly, slightly jerky. Driver side no problems.
    Bet is something to do with an old regular however was wondering if any know of a "trick" or lubricant that I can use to avoid taking the door apart :)
    Thanks for any help.
  2. GatedF355GTB
    GatedF355GTB Karting
    227
    SF Bay Area
    Joe
    Yes. Dry silicone spray is your friend. Spray it on the window seals and in the mirror housing and rear triangular shaped housing above the key hole.
  3. montegoblue
    579
    East TN
    Excellent! Thank you, will give it a try.
    GatedF355GTB likes this.
