360 - Window lift issue | FerrariChat
360 Window lift issue
Discussion in '360/430' started by MarioCG, Feb 5, 2023.
  1. MarioCG
    MarioCG Rookie
    Aug 13, 2022
    24
    Norway
    Mario
    I have a 2000 mod 360, where the window lift mechanism have been replaced. On the car itself its 3 pins to connect to the lift. But on the new mechanism its 6 connectors. Any one who knows if its changed on newer cars, or have a scheme so you can rewire it so it will work with window up and down and the down function on the window when you open/close the door?
  2. Qavion
    Qavion F1 World Champ
    14,374
    Ian Riddell
    Mario, do you mean 6 pins or 6 connectors? 3 pins or 3 connectors?
    By "lift", do you mean the motor only or a larger assembly?
    The window motor (itself) should either have a 6 pin plug (early car) or a 2 pin plug (later car). Here's an early version (see "6M"):
    (as viewed from the wire side..... I think)
    Here is the new connector
    (as viewed from the wire side of the connector..... I think)
    I don't know which is the "up" or "down" wire, but if you match the colours, it may work.
    I think only the Ferrari V12's (slightly before the Modena) used more than two pins on the 6 pin motor connector.
    If you have access to the main door connector (door side), you can check the wiring here:
    I don't know if the motor internals are the same.
    Please let us know if it works ;)
    EastMemphis likes this.
  3. Qavion
    14,374
    Ian Riddell
    #3 Qavion, Feb 5, 2023
    I guess the hookup will look something like this (looking at the contact side, not the wire side), but confirm the wiring of your 2 (?) pin "6M" plug by either pulling back the rubber boot (if possible) or by carrying out continuity checks from the main door plug.
    If the motor plug on your car really has 3 pins, then we have a major problem.
    Does the motor itself have numbers printed on the pins? If possible, please take photos of your plugs and post them here.
  4. Qavion
    14,374
    Ian Riddell
    #4 Qavion, Feb 5, 2023
  5. Qavion
    14,374
    Ian Riddell
    For FerrariChat future reference, here is an old type 360/456/550 window motor with a 6 pin (white) plug.
    Make sure you buy the correct type.
  6. MarioCG
    MarioCG Rookie
    Aug 13, 2022
    24
    Norway
    Mario
    Sorry for not replying here earlier, been out of town for work. I got wrong motor, so i have replaced it with the correct one. Similar plug as this one. With 6 pins and only two wires connected, but the window is not going down a bit when the door opens. Maybe its some learning adjustments to do?
    I removed door panel on driver side and lubricated and cleaned up a bit on both sides. Since the car sometimes cant be locked. You can hear it locks and then suddenly opens again. So im hoping that a wire was a bit slow.
    Qavion likes this.
  7. Qavion
    14,374
    Ian Riddell
    I'm not sure what's going on here. Did the motor change involve removing or disturbing door latch/lock components? Did you have any doorlock issues before this?
    This can be caused by a number of things:
    Something mechanical stopping the lock actuator from moving to its correct position (including the door not being latched closed properly).
    Faulty lock actuator.
    Faulty microswitches.
    Locking problems can be caused by either door, but its more likely to be the driver's side door (as you were working on that).
    Can you lock the door using your key?
  8. MarioCG
    MarioCG Rookie
    Aug 13, 2022
    24
    Norway
    Mario
    If i lock the door with key or fob then the same thing happens. It locks and then opens again right away.
    I checked and it seems that right side door handle is very slow. Need to clean it up and see if it Get into position by itself
    Qavion likes this.
  9. MarioCG
    MarioCG Rookie
    Aug 13, 2022
    24
    Norway
    Mario
    Adjusted the wires a bit on the outside door handle so that lifts up equal as the one on the other side. To lock the CAR with fob or key works now. I got correct window lidt mounted in. Nothing happens when i try to open the door from inside or outside. I turnes of power with button in trunk and left it overnight. Opened the window with the window button and closed it and hold the button for a couple of second, then it dips down a little. But with the door handles nothing happens. Microswitch or working issues?
  10. Qavion
    14,374
    Ian Riddell
    Do you mean nothing happens to the windows?
    I'm trying to figure out which version door wiring you have. Can you use the small lock lever on the interior door handle to lock and unlock the doors?
    Does the window drop when you use the key in the door lock?
    There are separate microswitches on the inner door handle, the door (key) lock and the outer door handle with separate wiring to the Window ECU. It's unlikely that all switches are broken. If you answer my questions above, we can make get a better diagnosis. If all three microswitches are not activating the window then, most likely, you have a Window ECU issue.
    I would check the plugs on the Window ECU, especially the bottom plug "C" (the smaller one with 16 pins).
    Look for water ingress / corrosion. Note that you should get an earth (ground) signal on these pins from the microswitches when you lift the handles or unlock the doors.
    The window ECU should be under the dash, near the RH side of the car (near your left knee if you drive a LHD car). It should be a green box (or black if a very early 360).
  11. MarioCG
    MarioCG Rookie
    Aug 13, 2022
    24
    Norway
    Mario
    When i lock the car with the key in the door nothing happens with the window. I can not lock the door with the small lock lever on the interior door handle I attached a image of the components under the dash. Which one is the window ECU? Is it one for each side so its possible to swap them and test?
  12. Qavion
    14,374
    Ian Riddell
    #12 Qavion, Aug 27, 2023
    Sorry, I meant to say LH side of the car, near the driver's left knee.
    Your box may be green.
    If I'm not mistaken, the connectors are marked A, B & C as shown.
    Unfortunately, there is nothing interchangeable.
  13. Qavion
    14,374
    Ian Riddell
    For future reference, those components in your photo are the Suspension ECU (top), the Windscreen Wiper/Washer Module and the Hazard/Turn Module (green)
  14. MarioCG
    MarioCG Rookie
    Aug 13, 2022
    24
    Norway
    Mario
    This box there then:)
    So if i lift up any door (either left or right side) handle i should get a ground signal on thoose wires?
    The connections on that box are fine, no water or corrosion on them...
    Qavion likes this.
  15. Qavion
    14,374
    Ian Riddell
    #15 Qavion, Aug 27, 2023
    Yes, that's the one :D
    Does the bottom, forward plug have 16 or 20 wires? The 16 wire plug carries the data from the lock microswitches in the driver's door to the ECU.
    What about unlock with the key?
    Did you notice if you have two microswitches on the interior door handle? i.e. One connected to the door opening lever and one connected to the lock lever (or is your lock lever purely mechanical)?
  16. Qavion
    14,374
    Ian Riddell
    I can't tell from your photo if the smaller bottom plug is actually plugged in.
  17. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    I would check the microswitch activated by the inside door handle.
  18. Qavion
    14,374
    Ian Riddell
    #18 Qavion, Aug 27, 2023
    No, they are specific to the driver's door, but yes, you should get a ground on pin 16 if you lift the driver's door handle or unlock the door using the key.
    You should get a ground on pin 6 if you lift the outer door handle.
    Sorry, I have to correct my earlier diagram (seems I was having a bad day yesterday)
    For the passenger door, it's pin 13 (pink wire) and pin 5 (grey/black wire) respectively.
  19. Qavion
    14,374
    Ian Riddell
    I'm just concerned that @MG is not getting a response from multiple door switches (although I need to confirm that unlocking the door does not move the window). I think he has an early car, so less wires to check (less microswitches)
  20. Qavion
    14,374
    Ian Riddell
    @MG Here are the wiring diagrams for an early car, but they are quite complex
    Here is the driver's door:
    https://www.dropbox.com/t/Rv5pPd6uzEGwBeG1
    The microswitch wires 8M (inner door handle) and 4M (key) both go to pin 11 (via a splice "S38M").
    Microswitch 5M (outer door handle) goes to pin 12 on the main door plug.
    Then you need to switch to a larger diagram:
    https://www.dropbox.com/t/P1fnIaWS89lsFbLP
    Follow the wires from the driver's main door plug (1F) to the Window ECU plug 14F (also known as plug C)
    Here is the passenger door:
    https://www.dropbox.com/t/CSWLceLa6oO7n01U
  21. MarioCG
    MarioCG Rookie
    Aug 13, 2022
    24
    Norway
    Mario
    The car is a 1999 model, the lock mechanism on inside is mechanical from what i can see, its a metal rod connected to the lock button and it goes to the back of the door.
    If i unlock the door with the key from outside there is nothing happening with the window at all(both doors lock and unlock by using both the key and the fob). If the car is unlocked and i open it from inside or outside the window does not go down a bit. If i use the window button and closes the window and hold it there then the window goes all the way up and then a bit down after a short time. So that might show that the ECU is working as it should but the micro switches or wiring is the culprit. Ill dive into the diagrams and see what i can find out of that part if its the wires that are broken.
    Qavion likes this.
  22. Qavion
    14,374
    Ian Riddell
    #22 Qavion, Aug 28, 2023
    Here is the microswitch on the door handle (5M in the wiring diagram):
    Here are the microswitches on the key assembly (4M in the wiring diagram):
    There are 3 microswitches on the key assembly. They are triggered by cams on the key barrel. Only two seem to be wired into the window circuit. The light blue, black and red wires are the wires in use. Oddly, red seems to be the earth (from the car's perspective).
    The innner door handle microswitch (8M) is here:
    Actually, that's the later model one with an additional microswitch on the interior lock lever.
    I haven't figured out what part of the system would cause this.
    You're not getting responses from multiple switches and different wiring to the ECU. At the moment, I can't see how anything but the ECU plug or ECU can cause this unless there is an input from a particular switch on the window itself. Maybe the system thinks that the window is already down. There is another switch on the window mechanism:
    This is 7M in the diagram.
    There is a message thread on the forum discussing this switch. It's a very long and convoluted thread, but here is one message relating to the operation of this switch.
    https://www.ferrarichat.com/forum/posts/148463270/
    If you have access to the plug on this switch already, try disconnecting it and then operating the door handles/key. Don't be surprised if the window runs all the way down :D
    Switch video here (thanks to @Mario Andretti )
    Other than that, all I can suggest is checking microswitch operation at the ECU connector pins or at the door connector (whatever is easier).
  23. MarioCG
    MarioCG Rookie
    Aug 13, 2022
    24
    Norway
    Mario
    Been away from the CAR for a while and have been using it at it has been.
    Today i rippes off door panel and wanted to Get to the bottom of this issue. I took apart and tested all microswitches on the door. They work. Took the connector on the door off and tested Ohm on all wires and working. And moved over to the black box that controlls the Windows and it looked like this. Any one have changed the relay with success? Or would a new box be the best way to go?
    Qavion likes this.
  24. yelcab
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    I would try changing the relay and clean up that corrosion. That relay is cheap and easy enough to find. It also has through-holes so much easier to DIY.
    MarioCG likes this.
  25. MarioCG
    MarioCG Rookie
    Aug 13, 2022
    24
    Norway
    Mario
    Finally something Easy:) On How it Looks i would say this might be the issue that the window Does not dop down when open the door.
    I found the complete part for sale for 100usd but will try to change the relay first
