Window Noise | FerrariChat
Window Noise
Discussion in '360/430' started by scud550, Jan 28, 2015.
  1. scud550
    scud550 Rookie
    Oct 20, 2014
    20
    Dallas, Texas
    Every time I lower my driver side window, about 3/4 way down, it sounds like there is something hitting the window. Happens when I raise the window too.
    Has anyone had this happen to them too?
    Jack
  2. Caeruleus11
    Caeruleus11 F1 World Champ
    11,621
    I've had this in another car, a long time ago, and in that case it was something to do with the window raising/lowering mechanism. I'd have it looked at but I wouldn't freak out too much.
  3. Speedster_4_me
    Speedster_4_me Karting
    Dec 10, 2013
    161
    SF Bay Area
    Jonathan
    In my 993 - it was a worn window regulator gear. At high friction spot it would jump which makes mechanical pop sound.
  4. houtie123
    houtie123 Formula Junior
    Dec 9, 2007
    548
    Cape Town, RSA
    Andrew
    Agree with Caerulius - not a huge deal. It happened on mine and the window mechanism had dropped inside the door due to loose bolts, causing the noise. 9 of times of 10 it's a reassembly and test - better to do that at an independent rather than a dealer. 1 of 10 its a faulty/damaged winder mechanism. I heard a common cause of mechanism failure is people pressing against the glass from the outside (i.e. spectators checking the interior out) which can put pressure on the mechanism. My mechanic did say if there is friction don't lower the window - the stress could break it then there's glass fragments inside the door card etc FWIW
