Window Regulator Splined Replacement Part | FerrariChat
Discussion in '456/550/575' started by Daniel Wanstrath, Apr 7, 2020.
  1. Daniel Wanstrath
    Feb 28, 2015
    15
    Cincinnati
    Daniel Wanstrath
    The aluminum splined part that holds both the window regulator arms on my 456 broke a few weeks ago. From what I read this is a common problem where they break or become worn or sloppy? My understanding is that most people bore out the arms and weld a stainless pin in place. I really didn't want to drill out the pieces, try to align them and then weld in place. I decided to see if I could replicate the original in stainless steel. I came up with a spline and bushing that can be pressed in place. Although its a press fit, it also has a center tap if you would like to add a washer and bolt. I have yet to reassemble, but wanted to see what others thought about the design before I finish the repair.
  2. tazandjan
    39,170
    Daniel- Looks like you have eliminated one more weak point.
  3. Daniel Wanstrath
    Feb 28, 2015
    15
    Cincinnati
    Daniel Wanstrath
  4. Daniel Wanstrath
    Feb 28, 2015
    15
    Cincinnati
    Daniel Wanstrath
    I got the regulator back in. Window gap looks good. Assuming the stainless splines hold up on the part, it should be a good fix that is easy to install without the need for additional machining and welding.
    white out and philfrench like this.
  5. Qavion
    Qavion F1 World Champ
    14,292
    Ian Riddell
    That's a work of art. How many hours did you invest in this? :confused: ... and how many copies will you make for your fellow suffering FChatters? :D
    I'm surprised Hills Engineering UK don't make them.
  6. tazandjan
    39,170
    Nice machining on that one and it does not look like it will ever wear out. How much to duplicate for your other V12 buddies?
  7. Daniel Wanstrath
    Feb 28, 2015
    15
    Cincinnati
    Daniel Wanstrath
    I've had a little extra time these days! Now that the design is complete and appears to work well, they can be made in quantity.
  8. Daniel Wanstrath
    Feb 28, 2015
    15
    Cincinnati
    Daniel Wanstrath
    I haven't looked at the machining cost yet. What do you think is a reasonable price?
  9. tazandjan
    39,170
    Daniel- No real clue, but anything under $100 would likely be good.
  10. Daniel Wanstrath
    Feb 28, 2015
    15
    Cincinnati
    Daniel Wanstrath
    That's probably around what they would cost. $95 each or $175 for a pair.
  11. tazandjan
    39,170
    Daniel- Should be a market at that price. F1 Imports might even be interested.
  12. Qavion
    14,292
    Ian Riddell
    Hopefully that's with some profit for you for your efforts?
    Note that several currencies have seriously devalued during the coronavirus (compared to the US dollar). Probably the US will be your biggest market, but having said that, I'm sure a few international folks are desperate for a proper window fix.
  13. phil99
    phil99 Rookie
    Feb 26, 2015
    35
    Wellington, NZ
    Phil S.
    I would be keen to get a couple, even with the exchange rate. Beautiful job!
  14. Daniel Wanstrath
    Feb 28, 2015
    15
    Cincinnati
    Daniel Wanstrath
    seatowntom and Qavion like this.
  15. Daniel Wanstrath
    Feb 28, 2015
    15
    Cincinnati
    Daniel Wanstrath
    Currently, if anyone who purchases the parts would like to send me their regulators, I would install them at no charge. I would like to document the install. PM me for details.
  16. rviani
    rviani Karting
    Jun 22, 2005
    81
    NJ
    Ron Viani
  17. rviani
    rviani Karting
    Jun 22, 2005
    81
    NJ
    Ron Viani
    In the process of removing my regulator - not sure how to PM - please email me at [email protected]
  18. Daniel Wanstrath
    Feb 28, 2015
    15
    Cincinnati
    Daniel Wanstrath
    My email address is [email protected]. Thanks!
  19. Prit Singh
    Prit Singh Karting
    May 29, 2017
    96
    London
    Hello Daniel my car seems have developed this gap. Are these bushings still produced?
    Prit
  20. Daniel Wanstrath
    Feb 28, 2015
    15
    Cincinnati
    Daniel Wanstrath
    Yes. They take 10 days from the order date to produce. If you are interested, please send an email to [email protected]
  21. seatowntom
    seatowntom Rookie
    Jan 14, 2021
    8
    Seattle, WA, USA
    Tom Feldman
  22. Davidspop
    Davidspop Formula Junior
    Dec 23, 2019
    401
    Lance Malcolm
    Mine worked awesomely and easy to install following Dan's instructions... I just now need to make minor adjustments but gap is exponentially better than it was!
    seatowntom likes this.
