Window switches | FerrariChat
Window switches
Discussion in '308/328' started by walawdog, Jun 5, 2007.
  1. walawdog
    walawdog Formula Junior
    Nov 9, 2004
    829
    Bluefield, WV
    Anthony
    I have a 78 308 and I noticed that every time my window switches stop working, it is a result of the small white plastic "plungers" inside the switch. Usually when I take the switch apart, the two white pieces are getting smushed (looks like the heat is melting them) at their tips so, I scrape off the excess plastic, clean up the metal contacts and reassemble and it seems to work fine for a while. It's a pain in the butt having to take the switches apart every so often. Has anyone replaced this soft white plastic part with maybe a harder material? If so, what did you use? Any other suggestions to fixing the stock window switches?
  2. walawdog
    Nov 9, 2004
    829
    Bluefield, WV
    Anthony
    No one here has addressed this problem? I can't believe it.
  3. Steve Magnusson
    26,931
    Had to do the same thing myself periodically and never pursued something different -- although had more trouble with the contacts oxidizing than the plastic bits.
