Window trim removal | FerrariChat
Window trim removal
Discussion in '360/430' started by Ksullender, Feb 5, 2013.
  1. Ksullender
    Ksullender Formula Junior
    Sep 3, 2003
    887
    Has anyone removed the (note sure of the correct part description) black trim that is on the roof line above the side door windows? If so how are they removed?
  2. casey330
    casey330 Karting
    May 12, 2011
    107
    Huntington Beach, CA
    Casey Dalley
    The roof rail trim is held on by a series of phillips screws that should be visible when the door seal is pulled down, the problem is there is 4 or 5 screws that can only accessed if the rear quarter glass is removed. The rear quarter glass is glued in and an extreme pain to remove
