What is the proper point for the hose to go from the pouch to the pump? I had it entering through the little door where the brake/clutch liquid reservoirs are. After a trip to the mechanic for routine service, I now noticed he rerouted it through the bottom of the car. If this is correct, i should be grateful, except he broke a piece of the batchboard door in the processs
The hose should be routed through the hinged brake reservoir door. Most Dinos I have seen have a notch on the upper corner of the door to allow the hose to pass through.
