OK - I have no windscreen washer on my 1998 355GTS When I pull the stalk towards me it activates the wipers but there is no noise of a motor trying to work - I can't see a fuse given for it in the handbook Any kind person with any suggestions as to what may be wrong Thanks Matt PS The fluid is full and not leasking
Good intuition Watson !!! Jokes on a side, i believe the motor washer pump is located in the trunk and the cover to access it is on the passenger side. Unplug the connector and power it up with an external power source. That should tell you if the washer pump is good or not ...
Thanks guys, I'll have a butchers ...also has anyone worked out how to silence the annoying "plip" when using the remote fob?? I'm sure the Aussie funsters will have a similarly hilarious reply as above - which I look forward to enormously! Ta Matt
