348 - Windscreen wiper park position | FerrariChat
348 Windscreen wiper park position
Discussion in '348/355' started by Mavic850, Sep 1, 2021.
  1. Mavic850
    Mavic850 Rookie
    Apr 25, 2021
    43
    Guy foulger
    Anyone had issues with the windscreen wiper park position when using intermittent wipe?
    Periodically the park position stops being at the base of the screen and ends up part way through the wipe range.
    Is this a fault within the motor assembly or is there a control module somewhere, any known fixes?
    I can’t say park following normal wipe is always perfect either.
  2. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,501
    Jeff
    Check the nut that secures the linkage to the wiper motor - mine had worked loose and gave the symptoms you describe above.
    NB RHD car shown so linkage will be on other side in US
    308 GTB and Qavion like this.
  3. Mavic850
    Mavic850 Rookie
    Apr 25, 2021
    43
    Guy foulger
    Thanks, that’s a good shout. Will have a look.
  4. 26street
    26street Formula Junior
    Jan 30, 2021
    343
    Westchester New York
    Mark k
    The wiper motor has a switch inside that holds 12v to the low speed setting of the motor after the controller turns power off once the the arms reach “park” then the switch will open
    If the wipers are going pass their range meaning hitting the a pillar or cowl then I would check wiper transmission arms
  5. Mavic850
    Mavic850 Rookie
    Apr 25, 2021
    43
    Guy foulger
    Thanks for the tip. The range of motion is normal, no contact with anything. The only issue is where they ark. Not yet stripped it down to check the motor shaft bolt.
