windshield washer fluid does not function on Gallardo I have enough fluid in the reservoir but it does not spray on the windshield. The motor runs, b ut the fluid does not come out of the nozzle. Any areas I can start looking at for the potential problem. Any suggestions
Check for hose leaks on the pumps. You have to take out the trunk bin to get there. If there's a broken or disconnected hose, it should be obvious since fluid is probably spewing everywhere. If it's not the hoses, are you sure the pump is running? You can hear it? If it's the pump, you can replace it from $15 up to $300 depending on where you get the pump. It's a bit of a pain to get to...
