Windshield Replacement | FerrariChat
Discussion in 'Maserati' started by Iceblue, Jan 21, 2013.
  1. Iceblue
    Iceblue Formula Junior
    Nov 5, 2012
    424
    Virginia Beach
    Olivier Perault
    I am contemplating on replacing my windshield on 62GTI
    There are lot's of scratches and pits...
    Has any one had any problems that I need to be aware of before starting this new task.
    There 12 bolts all the way around in the inside....
    If anyone could give me some advice, I would greatly appreciate it..
    Olivier
  2. Quattroporte3
    Quattroporte3 Formula 3
    Nov 13, 2010
    1,060
    Are you looking for a source for a new windshield, or advice on how to remove and refit the one you have?
  3. Iceblue
    Nov 5, 2012
    424
    Virginia Beach
    Olivier Perault
    I pre purchased from MIE a new windshield
    I am looking to see how easy or problematic it will be to remove and re install the new windshield.
  4. Quattroporte3
    Nov 13, 2010
    1,060
    In that case, Frank, Trevor, or Ivan would probably be your best bet.
    Good luck!
  5. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
    This is not a job to be taken lightly. This might be a good time for Mark Mcfletch to weigh in as he has just replaced his.
    Ciao,
    FGM
  6. 3500 GT
    3500 GT Formula 3
    Nov 2, 2008
    1,479
    Gentleman Racer
    Frank's right, look at all of Mark's thread,...
    Taking it out is the easy part. Do you have a new seal? Fit the seal to the windshield and check for fitment. Then fit it to the car i.e. make sure you've got the correct one.
    Try Mark's thread there is a lot of good information and problem solving there!
    http://www.ferrarichat.com/forum/maserati/227872-3500gt-barnfind-32.html
    Need more?......
    Ciao and best,
    Trev
  7. thecarnut
    thecarnut F1 Rookie
    3,230
    Atlanta
    The Car Nut
    Have you considered having your current windshield polished? Replacing a 3500GT windshield is not a fun task.
    Ivan
