Windshield replacement - | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by worth it, Jan 7, 2005.
  1. worth it
    worth it Formula Junior
    Oct 31, 2002
    299
    North Carolina
    David C.
    Just noticed a small rock chip in my windshield. I know my insurance will cover for the cost above my deductible.
    My question is does my 348 Spider require some crazy type windshield or is it a common material that a local repair guy would stock or order.
    Anybody with experience with this ?? Just curious before I start to make phone calls.
    P.S. In North Carolina they can not repair a windshield if it is anywhere in the drivers view / side. Stupid law.
  2. Ricambi America
    Ricambi America F1 World Champ Sponsor Owner
    Dec 7, 2003
    16,459
    Winston Salem, NC
    David -
    Where ya been? Call me on my cellular number. Got oil?
    -dp
  3. BlindBoy921
    BlindBoy921 Rookie
    May 23, 2004
    23
    Hi there,
    For what it's worth, I have worked for an Auto Glass company that is owned by some family friends the past 2 summers for a little extra money while attending college. The company I worked for is relativly large, and has some national credit, as it has warehouses throughout the country and is a fairly large operation. I only mention this to give a little bit of credabilty. My employer knows what he's doing :)
    That said, he has only ever done a few Ferrari windshields, as Ferrari's (or any real exotic car) are relativly rare in my part of the country. To answer your question, no, ferrari windshields arn't anything special - they would use a normal windshield like any other car. I would assume you could use an aftermarket brand, which would be cheaper, or have the repair shop use an OEM Ferrari shield, which I'm sure would cost quite a bit more. Expect around $350 for an aftermarket shield, give or take some. Not sure on an OEM Ferrari shield.
    However, if you just have a chip, most compitent shops should be able to almost completley remove it. There are some criteria, however. The chip usually has to be SMALLER than a quarter, or repairing it becomes to much of a risk (the whole shield could end up cracking). Also, as you mentioned, most, if not all, shops will not repair a chip that is at eye level infront of the driver (This has to do with the fact that the solution used to fix chips tends to add a slight "warping" effect to glass, making the view wavy in that tini-tiny area. It's dumb, I know).
    Hope some of that helps, if you have any questions I'd be more than happy to answer, just respond or hit me with a PM.
    Good luck!
    Travis
  4. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    $350 for a Ferrari windshield! Deam on...An aftermarket or OEM windshield is going to cost you $1k or more, not counting installation. Check with TRutlands, he always has a good supply in stock.
