windshield vents removal | FerrariChat
Discussion in '360/430' started by svolk, Aug 2, 2012.
  1. svolk
    svolk Rookie
    Nov 8, 2010
    38
    Sarasota Fl
    #1 svolk, Aug 2, 2012
    2000 360 coupe.Finally these vents have become "sticky". Any help in removal technique appreciated. WSM state entire dash/steering wheel, hub, etc must be removed. Possible to remove plastic vents without going through all this? Thanks
  2. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,842
    Jupiter, FL
    Paul Bianco
    did you try and pop them out? I don't believe you have to go through the process you mentioned from the WSM.
    when mine became sticky, I simply took care of it while the vents were still in place. I taped light cardboard to the inside of the windshield and then proceeded to clean it a small section at a time.
  3. delaney
    delaney Formula Junior
    Nov 8, 2003
    717
    Montgomery TX
    PETER DELANEY
    The vents just 'pop' out. Put a small plastic screwdriver under the bit that rotates to stop/start airflow, and pry it out carefully. Takes 30 secs/vent.
  4. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    He's talking about the windshield vents, not the main dash vents. Are you certain that the windshield vents can be pried out?
  5. Sled Driver
    Sled Driver Formula Junior
    May 13, 2010
    494
    Stokesdale, NC
    Emery
    The vents at the base of the windshield cannot be removed from above. The upper dash needs to be removed to access the screws the hold the vents on the dash.
    If you "pry" on them from above, they'll end up “permanently” removed, with broken retaining studs.
  6. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
    correct, there are 3-4 plastic tabs that will break if you pry and I'd say it's possible to break the vent itself if you pry. A previous owner had attempted to remove the vents to de-sticky them. So one was loose and the other still in place. So I've seen the tabs that will break off.
    As described above, I used 70% rubbing alcohol on small swatches of paper towels and some long Q-tips and carefully rubbed off the sticky. Worked perfectly! took about 20 minutes for each one but they look new.
    Just protect the area around the vents and you'll be a happy camper in an hour.
  7. svolk
    svolk Rookie
    Nov 8, 2010
    38
    Sarasota Fl
    Thanks to all for info. Will proceed with manual cleaning of vents in place. Shouldn't be too bad as noted.................
  8. svolk
    svolk Rookie
    Nov 8, 2010
    38
    Sarasota Fl
    Manually cleaning done; took ~30min. each vent. Used cloth wrapped over finger for most of cleaning (small hands), touched up with q-tips and various wood sticks wrapped with cloth. Used flat paint stir stick wrapped with cloth to clean up base of windshield after vents finished. An effective yet simple DIY for free (well, actually a "one beer job").
  9. Bob in Texas
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
    Glad it worked out! They now look a lot nicer, don't they. The forum is great as someone has usually been there, done that.
