Hey, Does anybody know how to get access to part #33. My windshield washer suddenly stop working and I got a suspicion that #33 is the problem. Thanx! Image Unavailable, Please Login
So I am assuming you can hear your washer motor working when you activate it? Or is water leaking out from that area where the joiner is?
Thanx for the reply PAP Is "removing the boot trim" an easy job? And are there a correct way to do it?
I just performed this exact thing for the exact same reason. It is not as difficult as it appears-but you do have to remove the bonnet lining Start by pulling off the rubber seal (do not pull it right off as it is easier to reinstall later, just pull from windshield down towards the nose) Then you will have to unscrew the three metal braces in the bonnet they are held by three screws each 2 long 1 short The little plastic splitter you are looking for should be located underneath the drivers side wiper you might need long needle nose pliers to work on it pretty tight spot. My problem was that the hose end was too loose and popped out I had to re splice and refit, total job took about 1/2 hour. Good luck.
Here are some pics of me lifting off the rubber trim. And the screws that need to be removed. Image Unavailable, Please Login Image Unavailable, Please Login
