WINDSHIELD WIPER PROBLEM | FerrariChat
Discussion in 'Technical Q&A' started by armani2, Oct 4, 2006.
  1. armani2
    armani2 Guest
    Dec 18, 2005
    36
    UPPER MARLBORO MD
    GREG AKA MIKE LOWERY
    IF MY HEADLIGHTS ARE ACTIVATED ON MY 1985 TR,AND I TURN ON MY WINDSHIELD WIPERS.THE LIGHTS POP UP AND DOWN.FOR NO APPARENT REASON CONSTANTLY.ANY SUGGESTIONS
  2. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Bad earth on the steering column, I bet as the wipers sweep accross your windscreen the heads light bob up and down in sequence ;)
  3. armani2
    armani2 Guest
    Dec 18, 2005
    36
    UPPER MARLBORO MD
    YEAP,YOU ARE RIGHT.SO WHATS NEEDS TO BE DONE
  4. armani2
    armani2 Guest
    Dec 18, 2005
    36
    UPPER MARLBORO MD
    THANKS, A SHORT IN THE STEERING COLUMN.
  5. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Has anyone done any electrical work to your car recently?
    I would remove the trim around your steering column and feel around for any loose wires/wire looms that appear to bolt to the column and surrounds and also to the headlights and wiper switch.
    See what path that takes you, Its obvious that your problem has just started so i'd imagine that it couldn't be to technical or difficult to find.
  6. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Sweet :D
    Is the cheque in the mail :eek: :p
