2002 360 Spider Windshield Wipers wont move when turned to the on positions. HOWEVER; they function perfectly if you engage the windshield washing function. Any ideas? e
It's not the motor then since the wipers swipe when nozzle is on. Perhaps it's the switch? Does the fuse look alright?
Should I check the fuse? I figured it wouldn't be the fuse because they still wipe with the washer activated. If think I should check to see I will. Where is the fuse for the wipers?
Fuses should be in the footwell. Not sure if it's driver or passenger side. I would suspect passenger side first. Manual should tell you. Long shot but it's the simplest thing to check.
Fuse OK. FYI Its behind driver seat, 25A. There are also 2 relays. each 30A. I dont want to mess with those. I think I'll let the dealership deal with it at this point.
