Wine temps | FerrariChat
Wine temps
Discussion in 'Drink, Smoke, and Fine Dining' started by Meister, Dec 24, 2008.
  1. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Gents,
    Almost complete on building the bar downstairs.
    Picked up a 30 bottle dual zone wine cooler. I not big into wines, but was wondering what most people keep their Reds & Whites at?
    Red zone can go from 50-64
    White from 41-50
    I've gone 52 & 44...???
    IIRC James Bond (SC) loved his Rothschild at 52...=)
    Thanks, happy holidays
  2. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,417
    SFPD
    Dirty Harry
    55 temp/humidity for storage - chill white on windowsill or in fridge before serving
  3. cptdpt
    cptdpt Rookie
    Aug 22, 2008
    48
    ZG CO US
    Jaz Kokeny
    I keep everything at 14 C (reds, whites and bubblies). I don't like overly chilled whites so I find that to be a good temperature and it can be easily lowered a few degrees in an ice bucket or chill wrap. Likewise, reds can be brought up to ideal temperature fairly quickly as they breathe.
    www.winecomplements.net
  4. Andrew D.
    Andrew D. F1 Rookie
    Jul 6, 2008
    3,979
    Goodwood Ontario
    Andrew D.
    If you dont have a fancy fridge chill a red 20 minutes before serving, take a white out 20 minutes before serving.
  5. ZUL8TR
    ZUL8TR Formula 3
    Feb 12, 2008
    1,354
    Fishers, IN
    55 for reads, smidge colder for whites and you should be good to go. Just avoid large fluctuations. Wine wants consistent temps.
    Wine at normal fridge temps is too cold. As stated above, remove from fridge prior to drinking. If you get served a wine that is too cold, just cup your hand around the bowl to help bring the wine in the glass up a few degrees. Just don't make it a habit of holding any wine by the bowl, use the stem...that's what its for.
  6. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    So 44 for whites is probably a little too cold. More like 48-50??
  7. Scotty
    Scotty F1 World Champ
    10,497
    Oregon
    Scotty Ferrari
    I think it is hard to generalize (except about storage temps). Depending on the specific wine, it may taste best at any temp from about 40F (certain bubbles) to almost room temp. I think the generalizations given are good, though.
  8. wax
    Jul 20, 2003
    52,417
    SFPD
    Dirty Harry
    55 temp/humidity is for storage, not serving. Whites can take a slight chill before serving, some Reds can use a little warmth for same reason, but storage is for preservation, which is the name of the game.
  9. ZUL8TR
    ZUL8TR Formula 3
    Feb 12, 2008
    1,354
    Fishers, IN
    What he said.
    Next time you open a white, make sure you take a sip while really cold. You will notice that the fruit has disappeared and the acid is strong. As the wine warms a little, you will notice the acidity mellows and the fruit appears. Experiement some and it will start to make sense. Be a geek with a digital, instant-read thermometer for grins and giggles so you can see how the wines evolve as the temps change. Plus, the more you experiement, the more wine you get to drink as you expand your knowledge. This is the fun part.
  10. DrStranglove
    DrStranglove FChat Assassin
    31,497
    Google Maps
    DrS
    I try to keep my reds at about 60deg F. Serve at about 65. (Castle Temp.)
  11. fou
    fou Formula 3
    Feb 1, 2007
    2,232
    Central Virginia
    Call me the breeze
    I thought you keep your Mad Dog 20/20 on ice in the styrofoam cooler.
  12. vincent355
    vincent355 F1 Veteran
    6,516
    Wine Country
    Vincent
    that's the ticket. Industry standard for storage is 55
  13. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    The colder the storage temp., the slower it will age. There are reports for years of pre-phyloxera clarets preserved remarkably well in very cold Scottish cellars, some in the mid forties and with ice cold water running through them. Judge your consumption patterns and if you drink most of your wines within around 5-7 years then you may consider a bit warmer or around 60 degrees. Some very large wines (reds) with lots of extract and hense potencial longer life might not change much at lower temps for years, conversely biological changes in some wines are held at bay by lower temps, say at 50-55 degrees. 57 degrees seems to offer the best of preservation and proper short term aging and flavor development. If you desire longer term aging of big reds, 55 degrees seems to fit the bill.
