Wing warper! | FerrariChat
Wing warper!
Discussion in 'Aviation Chat' started by snj5, Jul 22, 2011.
  1. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #1 snj5, Jul 22, 2011
    While up working on the new little plane, I got to sit in and start up a full size 1909 Bleriot XI replica, that also used the originals' wing warping lateral control system. To recap, the Bleriot was the world's FIRST production aeroplane. It doesn't even have a floor. If you drop something in the plane -- bombs away!
    I had never before been in a wing warper, but Holy Cow! Those guys had to have some serious upper body strength. While the controls are conventional feeling fore and aft, lateral stick movement requires some SERIOUS heft to twist the lateral wings around the front spar by pulling on the outboard rear spar.
    Eric Preston, the California owner and pilot, says you simply don't fly it unless there is a dead calm. He said the first time he flew it it scared the crap out of him -- it wants to wander all over the sky and you are constantly fighting it.
    Makes you REALLY respect the guys that flew these across the English Channel!!
  2. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    #2 toggie, Jul 22, 2011
    I assume the "boomerang-looking prop" is a photo effect of a spinning prop, true?
    If not, that is one crazy looking propeller! :)
  3. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    They actually did dog fights in them too, the Fokker E3. One " nice" thing about wing warpers is how they could bite you at near stall if one wing dropped. If you applied opposite warp to lift the lower wing , you INCREASED the angle of attack of the lower wing and thus proceeded to stall the wing that you wanted to lift. That must have been fun.
    Russ, did you get my PM?
  4. Gatorrari
    Gatorrari F1 World Champ
    16,460
    Georgia
    Jim Pernikoff
    That's probably why Old Rhinebeck never really "flies" their Bleriot; they just do a short hop over the strip: take off, fly in the air for a bit, straight and level, and then land without ever turning the airplane. And I believe that theirs is real, not a replica!
  5. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Doesnt an aileron technically do the same thing?"
  6. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    Technically yes, ie: increase the lift. The wing warp rotates the entire wing section without increasing camber thus presenting the section at an increased angle of attack and promoting a separation of flow. The aileron increases camber and lift without changing the angle of attack and allows the leading edge to maintain the same profile in the airflow and preventing separation and stall.
  7. tazandjan
    39,163
    Russ- The later wing warpers, like the Fokker Eindecker series, and the similar Fokker M series biplanes D.I-D.IV, had much lighter controls, even though they were wing warpers. Technology advanced quickly in WW-I and they were able to build higher mechanical advantage into the roll control systems. The system was obviously obsolete, though, and the last of the M series biplanes used conventional ailerons. Not everybody had Fokker's touch, though, and the contemporary Pfalz E.1-E.IV aircraft were much heavier on the controls and slower responding than the Fokker Eindeckers.
    Taz
    Terry Phillips
  8. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    I was going to mention the E3 sensitivity as mentioned by Jim Appleby who built an exact replica in the 60's and he said that it was quite sensitive and tractable. If my memory serves me, Immelman invented the maneuver that bears his name while flying a Fokker E3.
  9. tazandjan
    39,163
    #9 tazandjan, Jul 23, 2011
    Bob- Affirmative, except we are not sure Max Immelman's Immelman was the full maneuver or more like a Chandelle. Power to weight was not an Eindecker strong point, even the 160 hp E.IV with two guns, so pure over the top maneuvers may have been difficult. The early Oberursel U.I and U.II engines were based on the Gnome engines at 80 and 100 hp, and the 160 hp U.IV was essentially two U.Is on the same crankshaft, so P/W was not that good. These engines had nowhere near the power or flexibility of the later LeRhone based, Ur series engines.
    Taz
    Terry Phillips
  10. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    I knew dat. A proper Chandelle is not as easy as it sounds, maximum gain in altitude, 180 degree change of direction, and minimum speed all coming together at the same time. An Immelman as done now; a half loop with a half roll at the top would be extremely difficult in an E3. Those WW1 pilots were brave guys.
  11. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #11 Wade, Jul 23, 2011
    Yeah, cameras can be weird that way... This is taken out the window of a C-47.
