Winshield Wiper Motor 1985 308GTSi | FerrariChat
Discussion in 'Technical Q&A' started by Ed_K, Sep 14, 2005.
  1. Ed_K
    Ed_K Rookie
    Nov 7, 2003
    13
    Hot Springs, AR
    Edward King
    A friend's windshield wiper motor will not turn on. You can hear the relay when you turn the wipers on. Any suggestions on how to access the wiper motor?
    Thanks.
  2. Verell
    Verell F1 Veteran Consultant Owner
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    I believe it's accessable once you remove the fibreglass shroud around the spare tire. If not, then you'll have to remove the panel at the back of the front driver's side wheel well to get at it. Both are easy to remove, just a handfull of philips screws.
    Sorry, but I can't remember which it is. took a quick look at the parts book & it didn't help.
  3. jwise
    jwise Formula Junior
    Apr 2, 2003
    781
    Portland Maine
    Verell is correct- access from the rear panel behind the front driver side wheel. Just a few screws and all will be revealed. Sometimes those panels may not have been removed for quite some time- so they may be a little stuck.
    There is also a panel in the front of the wheel well for getting to the blower, removing the spoiler, etc.
  4. Ed_K
    Ed_K Rookie
    Nov 7, 2003
    13
    Hot Springs, AR
    Edward King
    Thanks for the information. It sounds like a project for the weekend. Now, if the motor is bad???
  5. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    If the motor's bad you could have a problem, as they are pretty scarce, you might have to have it re-wound.
