Winter Storage: How long do you warm up your engine? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by ErikV10, Nov 21, 2007.
How long?
  1. 5 minutes
  2. 10 minutes
  3. 10+ minutes
  4. I don't start the engine at all
Multiple votes are allowed.
Results are only viewable after voting.
  1. drgek
    drgek Formula 3
    Jun 21, 2004
    1,142
    Gary
    +1. Same in Chicago.
  2. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    I voted for 10+ minuites. BUT, I'm with the camp that either you drive it long & hard enough to get the oil & exhaust up to temperature, or else don't abuse your engine by just idling long enough to dump gas into the oil & condensation into the exhaust.
    It's hard to get an adequate run up here in NE during salt season unless you get lucky & there's a good rain to wash the salt off, then a couple of dry days to dry the road. I have no concern about driving in cold weather as long as it's a good brisk run that heats everything up. Preferably at least 15-20 minuites at highway cruise speeds. Since I'm 20 min. from a highway, that translates to about an hour run.
  3. bwassam
    bwassam Formula Junior
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    I have a 308 carbed car. I warm it up until I get the water temp up to the first notch, about 140. Then I keep it under 5000 RPM until the oil temp gets up to 160, then I can let it rip. I usually drive it pretty normal, that it I tend to float with the traffic until I get out in the country then I turn up the wick a litttle. I don't drive it hard though. It's just too nice a car to tear it up slammin' gears and throwing it into hard corners with heavy braking and then rolling the tires sideways.
    Bob Wassam
  4. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    A proper "winterizing" would also include fogging oil/spray in the cylinders....running the engine would wash this off everytime you started it.
    As such I never start the cars for 6 months. And as said before 6 months really isn't that long.
    95% full tank
    Stabil
    No tire mats
    Battery out (unheated garage)
    Occasionally those moisture absorbing packs (moisture is not really a problem in the dry winters of MN)
    I agree with those who have said starting is doing more damage.
    Unless you can bring everything, trans fluid, exhuast, engine oil, coolant.....up to temp and boil the moisture out of each and or it's fluids, theres really no point.
    Thanks for the post about the Ethanol blended fuels..informative.
