Winter storage | FerrariChat
Winter storage
Discussion in '360/430' started by Badger, Nov 27, 2012.
  1. Badger
    Badger Rookie
    Feb 16, 2012
    30
    Manhattan Beach,Ca.
    #1 Badger, Nov 27, 2012
    I filled the tank with gas and put the factory charger on, should I do anything else? Fuel stabilizer? I have a 2008 F430. Open for all suggestions, stored in cold climate. Sorry, car will be in Minnesota.
  2. Spider360Matt
    Spider360Matt Formula Junior
    Mar 14, 2012
    595
    California
    You're storing it for the winter and you live in the Bubble? Are you planning on leaving somewhere? ;)
  3. donho
    donho Karting
    Oct 11, 2006
    154
    Naples, FL
    Michael
    I'd suggest a couple more things:
    Overinflate your tires to 50 psi (to help prevent flat spots).
    Leave the windows slightly cracked.
    Leave the car in gear with the parking brake off.
    I wouldn't add Stabil to a stationary vehicle with a full tank. It really needs to be added before you fill up so that it mixes throughout the tank.
  4. Scotsguards
    Scotsguards Karting
    Jun 12, 2011
    94
    Gray, TN
    RPB
    One more thing I suggest for good storage; park your tires on foam core, cardboard, etc. Not a good idea to let them rest on bare concrete. I do this all year round because I don't drive it everyday. I tried to put mine up for storage last year, but we had a super mild winter! I was driving it the week before Christmas. Good luck!
  5. fineito
    fineito Rookie
    Jan 31, 2010
    17
    I am trying a Car Capsule for the first time this year. I've heard good things about it. My Porsche 993 will be parked in the garage (Chicagoland).
  6. RDI
    RDI Formula Junior
    Jul 11, 2009
    284
    Ontario Canada
    #6 RDI, Nov 27, 2012
    Got one last year, fairly happy with it.
    For winter storage as mentioned above, add fuel stabilizer then fill up tank with gas, and drive for 20 minutes to get it in all the lines etc. I pump up tires to 50 psi, I park my car on foam tiles. A full hand wash, then polish then wax and full interior detail, then plug in trickle charger.
    I am curious why keep the windows open a small crack?
  7. Zxgarage
    Zxgarage Formula Junior
    638
    MD/ DC area
    Zack
    I have one... use for one winter on my 997 and forgot about it... I may use again on my Scud this winter.
    I am also using buckets of some kind of silica to keep any moisture under control.
    THE BEST THING YOU CAN DO TO YOUR CAR IS TO RUN ENGINE EVERY TWO WEEKS OR MONTH... SPECIALLY OLD CAR... IT IS A MUST!
    ALSO MOVE CAR FROM SPOT... JUST ROLLING EACH TIME TO AVOID TIRE DAMAGE.
    The battery charger sounds great on paper... I have over twenty and most of time do nothing to avoid battery problems... better disconnect the batteries if possible. I am ordering the one I already post about... let's see.
    I also add stabil... to prolong the gas quality... I have cars with same gas for two years and stabil keep the fuel smelling at least ok... If over 6 months I would replace gas before crank.
  8. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    I'd say the worst thing you can do is run your car every couple of weeks if you mean you're just starting it up and letting it idle for a while (going for a drive is something entirely different of course). All you do by letting it idle is get a load of condensation build-up in various parts of the engine ... not a good thing unless you can then drive it to "burn it off".
  9. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    +1 I would do pretty much the exact opposite of what zxg said
  10. Zxgarage
    638
    MD/ DC area
    Zack
    #10 Zxgarage, Nov 28, 2012
    Carb cars.... If I don't the ethanol will damage lines and fuel regulators... I am talking about my old cars.... That's how I had been doing for years, and had been working well so far.
    I idle, warm-up and rev-up several times, maintaing some mid revs, like if you are driving around the block.
    If there is snow outside, that would be the closest thing you can do to actually driving.
    I know where you are coming from, and I respectfully disagree... :)
    No, in reality what you said is true if just idle. You must burn the condensation, for sure.
    Every time I didn't do this process... I go into trouble. I am lazy and like to skip... Bang carb problems. The fuel injected stuff not that bad, besides battery charge. I am just reporting...
  11. Zxgarage
    638
    MD/ DC area
    Zack
    From the internet and we all know... If it is on the net, it must be true :
    Maintenance and Upkeep
    Even when storing a car for long periods of time, you should try to take it on a short drive once a month. A 30-minute drive will keep the fluids flowing properly and help prevent against corrosion associated with disuse. If you cannot get on the road, idle the engine for 30 minutes (just be sure to open the garage door). If you aren't able to run the car monthly, consider buying a trickle charger to keep your battery in shape. Trickle charging your battery once a month helps ensure it will work when you put it back in the car.
    Read more: Advice on Long-Term Storage for a Car | eHow.com http://www.ehow.com/way_5135750_advice-longterm-storage-car.html#ixzz2DWaCoVVS
  12. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    All good stuff.
    I'll suggest:
    Chocks to prevent rolling
    Only a quarter tank of gas or so
    You can add Stabil then drive around a bit to mix the tank
    Leave the doors unlocked
  13. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    ....and the "to start or not to start" debate while in storage mode rages on......
    I personally do not start my cars. None of the cars I store are / will be older than a 2001 Model Year. I have also had good luck with my process.
  14. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    NEVER start a car unless you can take it for a decent drive.
    You are doing lots of harm by just idling it or even keeping mid-revs. How old are your cars that you think you need to do this ? mine are late 1920's and early 1930's. You have to get decent heat into the motor to get out all the moisture that has accumulated and the only way to do that is drive it, idling won't do it.
    Rolling the car forward/backwards a few feet to minimize flat spots, not a bad idea but over-inflate and you don't need it.
    I am done...I wont get into the debate.
  15. Zxgarage
    638
    MD/ DC area
    Zack
    I agree with the tire pressure... other than that.... Do whatever make your boat float.
    Peace. :)
  16. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    I'm 100% with you on this. I would not start my car in the middle of winter if I weren't able to take it for a decent drive. What I used to do with my old 308 was turn the engine over by hand by putting a 36mm socket on the crankshaft "nut" -- I'd do this once every couple of weeks in order to guard against sticking valve train etc. etc. Spring would come around, my 308 would start first time, and I knew that there wasn't any nasty condensation in the engine. I also used fuel stabilizer and a battery tender. Easy.
  17. red3555gtb
    red3555gtb Formula 3
    1,356
    Woodbridge/Ontario
    Rocco
    I'am now also using the Carcoon, the thing I like about it is that the humidity level with in the carcoon is under control 40% to 47% is my preferred range for my 328GTB.
    I keep the windows down about 25% for air circulation.
  18. Black360
    Black360 Formula Junior
    Oct 11, 2010
    439
    East of Eden
    Steve
  19. djastral69
    djastral69 Formula 3
    1,896
    Fl
    David
    Solution, move to Florida with us and drive as much as you want :)
  20. Black360
    Oct 11, 2010
    439
    East of Eden
    Steve
    They claim that you have to keep the air moving, both inside and out.
  21. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Except when it rains. Daily?
  22. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,941
    Very good point about leaving the doors unlocked; I had assumed if the battery went dead though that you could still unlock the doors manually?
  23. diSCUDsted
    diSCUDsted Formula Junior
    Feb 23, 2010
    997
    ILLinois
    Agreed, except you must fill the tank FULL of gas! This also prevents condensation from building and sitting in the tank.
  24. red3555gtb
    1,356
    Woodbridge/Ontario
    Rocco
  25. Spyker 007
    Spyker 007 Formula 3
    Mar 31, 2008
    2,181
    The Netherlands
    Jeffrey
    #25 Spyker 007, Dec 3, 2012
    Back in the 1970's this would have made sense. ;) (Friendly rejecting your theory. :))
    Today's fuel/gas/petrol goes "bad" after aprox 3 months.
    (This would not happen ten years ago, it's just because fuels have changed over the years)
    For the condensation part.
    Today's fuelcells are not made of metal anymore and can't rust.
    Filling up would only benefit older cars with a steel petroltank to prevent rusting on the inside. These cars would also benefit from a yearly draining of the tank to get rid of any water in the tank.
    I leave the car 1/4 to 1/2 full for winter. When I start up for summer, first thing I do i fill up with fresh fuel to get a "fresh" mix.
