Winter storage | FerrariChat
Winter storage
Discussion in '458 Italia/488/F8' started by stormdk, Jan 8, 2015.
  1. stormdk
    stormdk Karting
    Aug 10, 2014
    73
    Sweden
    Quick question
    I have no power outlet in the garage that the car is parked in ;( So would you recommend to disconnect the battery? Or take the car out once ever 2 weeks for a looong drive??
  2. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    I rent two spaces and had two electrical outlets installed.
  3. SVCalifornia
    SVCalifornia F1 Rookie
    2,571
    Silicon Valley
    Keith
    Or a long extension cable!
    Note that removing battery power requires a specific power up sequence to make sure everything works correctly (including window retraction)...
    SV
  4. 707
    707 Karting
    May 29, 2014
    175
    Alex
    IF i had to choose. I would choose discounting the battery. I believe the manual shows you how and one of the terminals is a quick discount so i assume it was designed to do so.
  5. Caeruleus11
    Caeruleus11 F1 World Champ
    11,621
    I'm not sure if this would work, but could you go out every 2-3 weeks with a portable jump starter, hook it up to the battery for an hour or so and have it juice up the battery?
    I've had good success with these for emergency situations:
    Amazon.com: Jackco ZT50420 Pocket Jump Starter Deluxe Kit: Automotive
    Another thought is to investigate the cost of having an outlet installed.
  6. Carabinieri458
    Jan 8, 2015
    1
    Ferraris really require being trickle charged. I would suggest investing in an outlet for the car. All too often, I have seen electrical gremlins rear their heads with full battery discharge and then full charge and back.
    I would cost a couple hundred to get an electrician to run a 120v line. But, well worth it, considering your investment.
    C458
  7. phatteus
    phatteus Karting
    56
    New York
    Matt
    Mine is plugged in, but unheated garage. If I leave it for more than a month in winter, I'm low on juice and it barely starts. This doesn't happen in Spring/Summer/Fall.
  8. stormdk
    stormdk Karting
    Aug 10, 2014
    73
    Sweden
    thx for the replies
    garage is heated... so perhaps, a fully charged battery might last for 2 months... guess I will have to wait and see.
  9. 707
    707 Karting
    May 29, 2014
    175
    Alex
    It will not last 2 month. search through the forums. the battery has a habit of dying in 1-2 weeks.
  10. MuratC
    MuratC Formula Junior
    Jul 6, 2014
    539
    Istanbul, Turkey
    +1
