Winter storage | FerrariChat
Winter storage
Discussion in 'Technical Q&A' started by Jim Doling, Nov 25, 2021.
  1. Jim Doling
    Jim Doling Rookie
    Oct 28, 2021
    3
    Roc ny
    Jim Doling
    Any. Tips on putting a cali up for three months Have the tender and overfilled the tires and up on soft blocks
  2. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,440
    Santa Clarita, CA
    Sounds like you’ve done everything that needs to be done. I’m assuming it’s in a garage. Is it covered with a car cover to keep the dust off?Maybe put some preservative in the gas tank, but not necessary for only 3 months.
  3. Fcar tech
    Fcar tech Karting
    Oct 22, 2021
    108
    Always nearby
    XXXX
    Engine oil should be changed. Top fuel off, less chance of condensation forming in tanks. (NY gets pretty cold)
    You have most things covered..
  4. Turbopanzer
    Turbopanzer F1 World Champ
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    Check coolant for proper sub zero temp protection. Same for washer bottle. Advisable to remove battery from chassis and place in a warmer climate while using tender. If battery is stored on concrete floor, place a piece of wood between floor and battery to protect it. Concrete doesn't help battery life.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
    3 months is nothing ..air and charger ..done
  6. Ak Jim
    Ak Jim F1 Veteran
    9,754
    North Pole AK
    Make sure everything is fully up to temperature before you shut it off. Don’t start the car unless you are going to drive it and get it fully up to temp.
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
    +1
  8. c8spidey
    c8spidey Formula Junior
    Dec 10, 2018
    604
    westchester county ny
    lou g
    Although long term storage is vague but I've always over inflated tires when storing 4 months or more even in heated garage as recommended in my F8 owners manual as well as moving car a little from time to time so as to avoid flat spotting.
    What I'm confused about is --how do you move it every so often without starting it? --with consensus opinion stating NOT to start without driving, considering that storing means you're not driving for months.
  9. ridege55
    ridege55 Formula 3
    1,390
    Manhattan Beach, CA
  10. c8spidey
    Dec 10, 2018
    604
    lou g
    God will get you for this **it Head.
    ridege55 likes this.
  11. tazandjan
    39,318
    Yup, but he has to live in California.
    Solid State likes this.
  12. ridege55
    ridege55 Formula 3
    1,390
    Manhattan Beach, CA
    I know... Each year I try to decide where to retire but the weather keeps me here
  13. tazandjan
    39,318
    John- Affirmative, weather (4 seasons, all pretty mild and sunny) kept me in Albuquerque for nearly 30 years until the wife got car-jacked.
  14. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,808
    Weston, MA
    Paul
    When you say "up on soft blocks", do you mean the wheels are suspended, tires not touching the ground?
    If so, do not do that, it could cause suspension damage. For most cars the suspension is not meant to be dangling in the air for an extended period.
