Winter testing 2014 | Page 18 | FerrariChat
Winter testing 2014
Discussion in 'F1' started by DF1, Jan 27, 2014.
  1. freshmeat
    freshmeat F1 Veteran
    Aug 30, 2011
    7,290
    Hahaha.
    Nico Rosberg said in an interview that the cars are going at gp2 speeds and that it would be impossible to go faster around any circuit than the 2013 car...
    Bernie must be ragin' right about now.
  2. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    43,186
    ESP
    Bas
    More boost + more fuel + a couple more engines will fix that problem.
    In 2015 :(.
  3. TOOLFAN
    TOOLFAN F1 Rookie
    2,807
    California
    Agreed. However, I will try to keep an open mind. Honestly though, if it turns into endurance fuel saving 'racing', I hope it fails spectacularly and they have a complete re-think.
  4. Alex1015
    Alex1015 Formula Junior
    Sep 1, 2005
    949
    The way the fuel flow rate is structured coupled with the stiochiometric AFR there is essentially rev limit. Reving any higher would only make a more lean charge.
  5. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,968
    Atlanta
    John!
    With fuel flow being limited above 10.5k rpm I suspect peak bhp can be made right around 11k rpm if that, but is it not optimal to shift when maximum torque is in line with where the next gear falls ie. if shifting at 15k rpm, one would want the next gear selected to be at max torque as it's engaged, so 10.5k rpm or thereabouts. Unless of course these new gearboxes have very short gears allowing max torque to be engaged minus ever needing to rev the engine beyond 13k or so.
  6. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,291
    Worcester, England
    Phill J
    They are now 8 speed gearboxes rather than the previous 7 speed so that theory might hold some water.
    I wonder if any of the drivers have been caught out yet by forgetting that they've still got another gear to go once they hit 7th?
  7. ingegnere
    ingegnere F1 Veteran
    5,567
    Montreal
    They have 8 gears because the gear set is "homologated" for the WHOLE (!!) season and must cater to Monaco as well as Monza, so possibly they are not using 1st (except for starts) and 8th gear at Jerez.
    I would presume self-imposed limitations are at play here.
  8. NJB13
    NJB13 Formula 3
    Jan 5, 2013
    1,317
    Pampanga,Philippines
    Norm
    I'd think Merc ran closer to full power than Ferrari for the simple reason they ran a full race sim. It would be fairly stupid IMO to run a full race sim and miss out on the critical fuel use validation data.
    Also, LaGazetta has said the Ferrari engine was held back at Jerez and will be given an upgrade for Bahrain. They also said there will be new front wing (no surprise there) new rear wing and body as well as the abovementioned dt upgrade. They call it a B-spec car.
  9. MisterMaranello
    MisterMaranello F1 Rookie
    Apr 5, 2011
    3,335
    Europe
    Yeah, that video really illustrates how quiet this year's cars are. Sad.
  10. Bas
    Mar 24, 2008
    43,186
    ESP
    Bas
    IMO a spectacular failure will be necessary to see more power changes happening much quicker...
  11. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,291
    Worcester, England
    Phill J
    Oops! - My bad! - I forgot about that one! :eek:
    I brushed up on it here: 2014 Rules | ScarbsF1.com
    It seems that for this season only they can change the ratio's once at any time but for next season there can be ratio change.
    It is also suggested in that link that with the extra torque of the engine, they may only actually use 5 or 6 gears in races, so going into 8th gear as I'd previously suggested could actually prove to be a bit embarrassing for drivers at some circuits!
  12. ricksb
    ricksb F1 Veteran
    Apr 12, 2005
    9,975
    Montclair Village
    B. Ricks
    Trackside reports indicate that no team ran at full power. The focus was on set up and reliability. We will see mor representative times at the upcoming Bahrain test.
  13. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    +1
    I think it was JB who noted that 1st/2nd gear corners were now being done in 3rd or 4th because of the torque they've now got.
    I also wonder if they could 'jump' gears by messing with the 'box ECU? Some tracks may be, say, 1,3,5,7,8 while Monaco would be a straight 1-6 for example. I guess they'd always want 1st for the start, but after that it could be very circuit dependent.
    Cheers,
    Ian
  14. Ferraripilot
    May 10, 2006
    17,968
    Atlanta
    John!
    I know Lewis and Nico both confirmed the same. The hairpin a Monaco for example will be a 3 or 4 gear corner where it was 1st before.
  15. CRG125
    CRG125 F1 Rookie
    Feb 7, 2005
    2,646
    Los Angeles, Ca
    Vivek
    [ame=http://www.youtube.com/watch?v=1wNnuNRMceM]Ferrari testing 2014 Turbo V6 F1 Engine on a LaFerrari chassis in Fiorano! - YouTube[/ame]
    I thought the Ferrari would sound like when they tested it in the La Ferrari. Listen towards the end of the video. It has that high pitched sound, which I like. Maybe Ferrari is still limiting the RPM?
  16. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,693
    Sarasota
    David
    This is going to be a fascinating season.
    One way or another.
  17. Remy Zero
    Remy Zero Two Time F1 World Champ
    Apr 26, 2005
    23,487
    KL, Malaysia
    MC Cool Breeze
    I think the teams are just making sure everything is in check before going a 100% with the engines and system. Just to check everything is working, etc.
    Maybe we will get better sound by the time Melbourne comes around. I've heard and watch some clips, and gotta admit...they sound horrible! Like the engine is constipating or something.
    But, i prefer to watch them live and make a judgement. Can't wait for Sepang this year.
  18. classic308
    classic308 F1 Veteran
    Jan 9, 2004
    6,820
    Westchester, NY
    Paul
    Nico thinks that f1 this year will not be about speed as the cars are slower but that it will involve more "in race" thinking. Massa says that he believes Fred will beat kimi as Fred is more intelligent. I'm not going to panic yet but between the ugly cars, lack of engine noise and speed, and potential fuel economy runs this may be the year I take a sabbatical.
  19. YAMVS6
    YAMVS6 Karting
    Jan 26, 2011
    138
    ohio
    slower cars? with more torque..will this translate into better lap times? or with they be about the same as last year?
  20. kraftwerk
    kraftwerk Two Time F1 World Champ
    May 12, 2007
    26,826
    England North West
    Steve
    I thought this was a interesting piece by Mr Saward.
  21. TifosiUSA
    TifosiUSA F1 Veteran
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    "The pinnacle of motorsports"
  22. tervuren
    tervuren Formula 3
    Apr 30, 2006
    2,469
    I'm very excited by the video's of seen from Jerez. The sound is great, and the car's look a lot better in motion than they do in "release" photos.
    Rear traction is gonna be at a premium, it will be interesting to see how the team's develop their cars over the season. Cars with less rear downforce + no traction control + more power means driver's will be a much bigger part of the equation.(As will engine/recovery system mapping)
    This will be like getting a little time machine to the late 1930's when tires couldn't keep up with the massive power the Grand Prix teams were coming up with in engine development. I'm looking forwards to it. ^^
  23. TifosiUSA
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
  24. freshmeat
    Aug 30, 2011
    7,290
    sounds like a turd to me...
    [ame=http://www.youtube.com/watch?v=PIZiB9KaYWM]Fernando Alonso jerez 2014 - YouTube[/ame]
    [ame=http://www.youtube.com/watch?v=I1_TrtqRLo8]F1 test día 3 jerez 2014 - YouTube[/ame]
  25. Ferraripilot
    May 10, 2006
    17,968
    Atlanta
    John!
    Sounds like the mid to late 80s to me. Love it. :D Can't wait for Monaco, talk about a toss up of a race this year
