Wiper motor DIY 59 | FerrariChat
Wiper motor DIY 59
Discussion in '612/599' started by swiss612, Sep 23, 2025 at 7:38 AM.
  1. swiss612
    swiss612 Karting
    May 10, 2016
    249
    Zurich
    Michel
    A friction noise developed when I turned the wipers the other day, since wiper motors are known to fail I decided to open it rather than buying a new one.
    The removal of the motor is straight forward, I opened the body which holds with 2 screws and found a loose magnet. The magnet detached because of rust. I removed the rust with sand paper and cleaned the body with brake cleaner. Once dry I used some epoxy to glue it back. These magnets are strong and I had to use tooth picks between the two half to keep them centered and against the body. While you are there, don’t forget to clean with sand paper the copper contacts on the rotor where the brushes make contact.
    a little trick to reassemble the body, take the 3 brush springs off and put the rotor first in the mechanism, put the spring back and then only put the black body. The body has a hole at the bottom, make sure it faces downwards when reassembled.
    It’s an easy diy job honestly and saves 700$ on the new part which sells only as a complete wiper module.
    It took 30 min in total to do this
    George Vosburgh likes this.
