355 - Wipers not working | FerrariChat
355 Wipers not working
Discussion in '348/355' started by cactussed, Sep 4, 2025 at 2:11 AM.
  1. cactussed
    cactussed Formula Junior
    Mar 12, 2008
    297
    Guys
    Italian electrics strike again,
    the wipers seem to be working but only when they feel like it.
    What I am finding is that the intermittent and normal speeds don't work, but putting them into fast mode sometimes fires them up, which in turn then means that normal speed will work and intermittent will then also sometimes work (for a bit).
    I presume the wiring is from the column stalk, direct to the relay under the frunk, and then to the wiper motor itself, so 'should' be simple to check?
    Is that relay actually a relay, or is it a minor ECU? I'd rather avoid paying a thousand euro for a replacement.
    Any thoughts on how best to proceed?
  2. Qavion
    Qavion F1 World Champ
    14,465
    Ian Riddell
    Minor ECU (expensive). Maybe try for a repair? I think they are getting hard to find. P/N 153095. Same part as 456 and 550 (and early 360's)
    Do the wipers work when you do a windscreen wash? Different column contacts are used.
    Do your brake lights work properly? Is there sufficient voltage on the fuse? Tired wiper motor?
    2.7 or 5.2?
    2.7 diagram here:
    https://www.dropbox.com/t/sP46M2e6T6yJyYMu
    Not really sure what all the pins do.
    Mike Morrissey likes this.
  3. cactussed
    Mar 12, 2008
    297
    5.2.
    Lights all work fine, so its not a fuse thing.
    On a wash, the washer unit works (ie sprays water) but again, wipers not always.
    It feels like a bad contact type of issue. Either a dodgy earth, possibly (but unlikely) a poor solder joint in the ECU or poor contact in the motor itself.
    Time to break out the circuit tester...
    Could just be an Italian thing and they just take August off?
  4. Qavion
    14,465
    Ian Riddell
    Since all the switch selections take different paths to the ECU, it either has to be a power wire issue, common ground or ECU issue, not a column switch issue. Or simply a wiper motor.
  5. cactussed
    Mar 12, 2008
    297
    Exactly my thoughts
  6. cactussed
    Mar 12, 2008
    297
    Update - Earth seems fine.
    When I wiggle the 6 pin connector, that gets the wipers working, so its not the motor or the column.
    Also not going to be the column wires as they're all affected.
    That leaves dodgy power connection (which looks like either socket 1 or 3)...
  7. cactussed
    Mar 12, 2008
    297
    So, got the cover off the ECU. Can't see anything obvious, and wiggling the wires does nothing, however slightly moving the 6 pin plug triggers the micro relay, which indicates (to my mind) a dry solder joint somewhere on the board, so am going to send it to a local electrics place and see what they have to say...
    Qavion likes this.
