He has that already I believe. It is in the link that he referenced earlier in the thread. http://workshopmanual.com/doc/d425-wiring-diagrams-360-spider I have been trying to find my picture of the relay fuse panel id plate for reference to make sure that those were checked but I cant find it just yet. So at present we are working on the front parking light circuit? That is powered though the switch in the center console. Is it possible that someone worked on the center tunnel and did not plug it back in? I think you can check it by removing the ashtray IIRC EDIT: I see by your picture that someone indeed removed the center tunnel part to paint it. They would have had to unplug this switch to get that part out for paint.
Whew this is a good brain puzzle. I started tracing your first problem first before I saw your EGT sensor problem. Is this the Catalytic Converter sensor that shows a "slow down" message on your dash? You need to concentrate there first IMO and see where that power goes. I am not sure what it is called in the wiring manual! I had some luck using this manual a couple years ago to plan an upgraded stereo speaker system and it was tough but I made my way after working with it a bit. I think your problems may be over my head but I can try to help if no one else has the time. I was getting lost following the rear light wiring so maybe best to try with the Cat sensor and see if by following it you can get to a relay or fuse area where these systems cross and start working there. Which item would that be from the manual?
There should be a decal on the inside of the panel you removed to see this that says what they are all for. I cannot find my picture of the decal to help. You may want to move this thread over to the 360 section so those guys can try to help.
Except when you click on the link this message appears. That document isn't available in pdf format. But what I have is in PDF and is 5 MB in size.
Additional? Doesn't your photo show the main fuses in the forward luggage compartment? (Page L34 in your manual) You have opened the cover on the fuse/relay panel showing fuses 19~24 and relays 33~36. FUSES 19: Left hand headlights (aft inboard fuse) 20: Dipped lights 21: License plate and switches' lights 22: High beam headlights 23: RH front and LH rear dipped lights (forward inboard fuse) 23: LH front and RH rear dipped lights RELAYS 33: Not used (may be related to fog lights on some cars?) (aft outboard relay) 34: License plate and switches' lights 35: Parking lights (forward outboard relay) 36: Dipped lights
I original poster asked if there is a drawn wiring diagram, not the plug labels and directions. I don't believe the wiring "diagram" he wants exists. That was my answer. I know there is a wiring diagram from Ferrari, just not what he wants.
I don't know if it began after the 360, but I believe, at some point, the genuine (authorised workshop) Ferrari wiring diagrams (on CD) had clickable links which allowed you to view "traditional" wiring diagrams (of the type Alex was wanting).
Is there any way you could email that pdf please. [email protected] Sent from my iPhone using FerrariChat.com mobile app
Dang... I wish I'd known about these. It took me 6 months to create my own diagrams. I'd be curious to see how they are drawn (similar to 355 diagrams or F430 diagrams?)
Attached is the best 360 wiring diagram I have found so far, it's a single and searchable pdf file, small enough to upload. Unlike the Ferrari Workshop Manual, it's English only, so easy to read (for those using English Unfortunately still "plugs and connectors" format
