Wiring route to rear number plate light | FerrariChat
Discussion in '206/246' started by yakxx21, May 17, 2015.
  1. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    Should this wire really be exposed within the boot lid and just stuck up with ' sticky stuff ' or should it be routed some other way. ?
    Seems rather Heath Robinson !
  2. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    So. It seems there shouldn't be any wire at all ???
    It seems I should have a contact on the lid ...??
  3. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,488
    Germany
    Matthias
    if you have the number plate light in lid, yes you should have a contact, no wire into the lid
  4. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    What I have in the LID is a tubular extention that looks like it should hold a little switch...and right now somebody has in previous times connected a loose wire via that little switch to the number plate light in the lid.... so now Im not sure what I want ??....
  5. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    I wonder if somebody could help me out. My boot lid has a conical extension that looks like a mini switch should be in place but other posts say I should have a power connection ... So I'm still unsure if I should have a power connector or a little switch and 12v from a floating wire
    Appreciate input
  6. Ken Ivey
    Ken Ivey Formula Junior
    256
    Portland, OR, USA
    Ken Ivey
    I consider the wiring to be rather counter-intuitive. Yes, you attach a spring loaded contact point on the batch-board. Leaving a live – bare power source when the driving lights are on. In the vertical tube on the boot lid is where the power pickup is located. I don’t know what the original looked like. So, I fabricated my own, insulating the contact point from the boot lid. I then lead a wire from that contact point to the light unit. It works and looks something like the original – I believe.
  7. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    Thanks ... Now I understand. Will do same
    Ken
