Wiseco 328 Pistons, need some data | FerrariChat
Discussion in 'Technical Q&A' started by dirk, Jan 20, 2005.
  1. dirk
    dirk Rookie
    Nov 4, 2003
    33
    Europe
    Dirk
    Hi,
    i want to let manufacture some custom made pistons at wiseco for an euro 328.
    I want to increase the compression ratio a little bit to 10.2:1
    I need to know the cc's of the cylinder head combustion chamber, the crushed thickness of the gasket you use, and how far down the piston is in the bore when @ TDC.
    Can anybody help ?
  2. GTO84
    GTO84 Formula Junior
    Dec 13, 2003
    566
    They might already make 328 pistons. Also how far apart is your engine? Do you have a 308 or a 328? Give a little background on your idea. Are you trying to put 328 pistons in your 308?
  3. dirk
    dirk Rookie
    Nov 4, 2003
    33
    Europe
    Dirk
    I need new pistons for my 328 engine, if they are custom made, my idea was to increase to compression ration a little bit.
    Dirk
  4. atlantaman
    atlantaman Formula 3
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    I am about to do an "engine out" on my 328 efi motor. I dont need to do anything to the bottom but really could use a bit more power for the track.
    Anyone have any experience with Weisco or JE. I called them both and they dont log their pistons by car type but to job numbers co they could not tell me if they had any 10.0 pistons are not.....
