Wishbone removal | FerrariChat
Wishbone removal
Discussion in '348/355' started by coledoggy, Apr 24, 2020.
  1. coledoggy
    coledoggy Formula 3
    Apr 8, 2007
    2,185
    ole miss
    todd
  2. PaulK
    PaulK F1 Rookie
    4,781
    Michigan
    Paul
    #2 PaulK, Apr 24, 2020
    I don't have my car in front of me so I am looking at the diagrams. I always thought that the mounting points for the wishbones were welded in, but it looks like they bolt on:
    Also, it sure looks like that bracket for the e-brake which is interfering with your bolt removal looks like that can be unbolted as well, or is it welded?
    You'll probably have an easier time unbolting that than the mounting point.
  3. coledoggy
    coledoggy Formula 3
    Apr 8, 2007
    2,185
    ole miss
    todd
    Ok, yes they do bolt in, the wishbone mounting points.
  4. PaulK
    PaulK F1 Rookie
    4,781
    Michigan
    Paul
    Yes but what about that e-brake bracket? That should unbolt I think.
  5. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  6. CLIVE77
    CLIVE77 Karting
    Sep 10, 2010
    151
    Upper Clatford, UK
    Clive Spencer
    Its an easy fix. Leave the wishbone on the fixing bracket and unbolt the bracket from the subframe. It'll just pull out when the nut is removed. Make sure you keep the shims so you can put them back in the right place.
    ShineKen likes this.
  7. ShineKen
    ShineKen F1 World Champ
    19,883
    Southern California
    Nostradamus
    Running into this same issue on the 355. Just making sure the wishbone can pull back out far enough to clear without removing top wishbone?
  8. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,629
    Elliott Caras
    Yes.
