430 - With manual gearbox | FerrariChat
430 With manual gearbox
Discussion in '360/430' started by evo11, Apr 6, 2025.
  1. evo11
    evo11 Karting
    Sep 21, 2020
    184
    K
  2. imahorse
    imahorse F1 Rookie
    4,268
    WI
    Dustin
    Unless something is bound up, the spring on the side pin should return it to center. If the snap ring holding the cover for the spring pops off, that springiness will be gone. Also there is a plastic box that the cross pin rests in. When those wear out the cross pin can pop out leading to leading to not centering right. If the shift lever bushing goes out (they were plastic on the 360, not sure if that was upgraded for 430) the shifter won't center either.
    Another thing to potentially do is to disconnect the shifter cable from the gear selector on the transmission. If you no longer have resistance in the shifter, that would mean the issue is with the shift selector on the gearbox or the gearbox itself. There is a spring in the shift selector that can sometimes get seized up.
    In all of these scenarios besides it being a gearbox issue, it's not an overly expensive issue to rectify.
  3. evo11
    evo11 Karting
    Sep 21, 2020
    184
    K
    Thank you !
    imahorse likes this.
  4. evo11
    evo11 Karting
    Sep 21, 2020
    184
    K
    So It turned out that the grease in the piston which is responsible for the return of the gear lever has dried up. Everything is disassembled, cleaned and greased and works like it left the factory yesterday
