488 - Wont go into accessory or wake up | FerrariChat
488 Wont go into accessory or wake up
Discussion in '458 Italia/488/F8' started by 95TURBOsupra, Jun 3, 2025.
  1. 95TURBOsupra
    95TURBOsupra Rookie
    Sep 30, 2016
    10
    Hello guys
    Wondering if anyone can shed some light on an issue.
    488 Spider
    Car sat for about 2 weeks. Started a few times not driven(weather). Was on the factory Ferrari tender.
    *Car won't honor key fobs, nor does the car even go into accessory with the start button on the steering wheel or the emergency start button.
    *New batteries in fobs.
    *New battery in car (just in case)
    *Main fuses on top of battery all good.
    *When key is inserted into the center tunnel location for emergency start, still inactive.
    Headlights work, taillights, frunk opens, top retracts, windows drop down with manual key in the door.
    *OBD port works, but only connects with one or two modules.
    *The cluster will display 488 and Ferrari logo when the door is opened. But then nothing else.
    Any direction or ideas I can check out?
  2. Snapshift
    Snapshift Formula Junior
    924
    Centralia IL
    Lyle D. Pahnke
    Have you tried disconnecting the battery for awhile and doing a reset? Thgat sometimes cures a few problems, essentially rebooting the car. Just a guess. Crazy that a car should even be doing this.
  3. 95TURBOsupra
    95TURBOsupra Rookie
    Sep 30, 2016
    10
    I will give it another try this evening.
    But it didn't work the first time. It is craziness.
  4. Snapshift
    924
    Centralia IL
    Lyle D. Pahnke
    Did anything work for you for this problem?
