Work so far on my 348 | Page 5 | FerrariChat
Discussion in '348/355' started by Paul V, Mar 28, 2006.
  1. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    Looks great Paul!
    Looking forward to more updates...
    Mike in Kuwait
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    Awesome work Paul! Those pics sure are nice. Are you going to port, polish, and flow the heads?
  3. Philip Barnard-Browwn
    Feb 25, 2007
    168
    london.
    Philip Barnard-Brown
    Paul you are more than welcome. Long live the BROTHERHOOD.
  4. Paul V
    Paul V Formula Junior
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    #104 Paul V, Mar 14, 2009
    Update
    Took the sump off and found the rest of the broken valve spring!
    The reason for removing the sump was to check out the oil pump and cam chain tensioners pads.
    Can anyone confirm from these photos if i have the old type or the new type??
    I think i have the old type pads and i think the new type bearing??
  5. MarkJ
    MarkJ Formula Junior
    Sep 10, 2006
    729
    NW Arkansas
    Mark Jones
    I just read thru this entire thread. Your work is awesome and inspiring. I can't wait to see the completed engine sitting in the detailed compartment.
  6. Paul V
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    #106 Paul V, Mar 25, 2009
    Nor can i wait Mark.
    Bit of an update, been working on the rear engine cradle. The 348 engine cradle seams to rust quite badly on the upright strengthens, i know Daniel had to have his ones re done.
    I started by having the lower part shot blasted so i could see what i was working with, as you can by the photos mine had been repaired before. All they did was cover over the old rusted parts nice !
    I removed all 3 parts completely (Sorry don’t have photos) and made new upright section out if box section tube, and then welded them back in the right place. The last few photos shows the new parts in place, the frame is now at the powder coaters getting sand blasted and re coated.
    Hope you enjoy
  7. Philip Barnard-Browwn
    Feb 25, 2007
    168
    london.
    Brilliant work Paul. Your car will be something special when finished.
  8. Paul V
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    #108 Paul V, Jun 22, 2009
    Thought i would update this thread.
    I have been working on the bottom end of the motor, i have cleaned the “pre oil filter” that attaches to the oil pump and installed new O-rings.
    I have fitted 2 new bearings and new tensioners pads with the later type ones, the refitted the sump.
    Not much more I can do to the motor until I get the new valve guides for the heads.
    I have taken the covers of the gearbox and put fresh lock tight on the ring nuts so I hope I won’t have any issue here.
    I sent the engine loom away to have all the boots and connector pins changed so will be putting that back in a few days.
    I have had the engine frame back from powder coating and they have done a great job, I also have had the entire nuts bolts brackets fuel rail Etc all Re plated and again they are stunning.
    I will post the photos next time.
    What I have posted photos of is the front brake set up I have been working on.
    The Calipers are Alcon racing 6 pot “mono blocks” , the rotors are AP floating type 378mm by 36mm wide, pads are Ferodo DS2500
    I had the brackets and bells made up, as you can see they fill the wheel quite well.
    Hope you enjoy and I will have some more photos in the next few days.
  9. PAP 348
    Dec 10, 2005
    100,245
    Mount Isa, Australia
    Pap
    Great pics mate! Those brakes look AWESOME!! :D:D
  10. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    I LOVE IT!!!!
    The pics of the oil chain tensioner are fantastic, and will help my out the next time I yank my engine.
  11. Paul V
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    #111 Paul V, Jan 1, 2010
    Small update, had made and fitted all new valve guilds, honed all the guild bores and then sent he head off to have the seats cut on a cnc valve seat cutter, see video here http://www.ultimatep.com/shopinfo_seat_profiling.asp
    Just in the process of building up the heads with all new valve springs, stem seals etc. Made a tool for inserting the stem seals as they are a quite “hard” going to set the valve clearance on the bench before i fit the cylinder heads to the engine.
    The body of the car is at the new paint shop, they have made all the panels fit as they should and removed all the paint, i hope to get the car back at Easter time then finally i can get on with the rebuild.
  12. PAP 348
    Dec 10, 2005
    100,245
    Pap
    Very cool pics mate! That paintshop look familar! ;);)
  13. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    No kidding Pap. Look like the same guys that did Sy's car.
    The video of the valve machine was impressive.
    Thanks for the update.
  14. PAP 348
    Dec 10, 2005
    100,245
    Pap
  15. captglen
    captglen Formula 3
    1,790
    West Palm Beach, Fl
    Glenn L.
    You are my idol, What a great job !
  16. Philip Barnard-Browwn
    Feb 25, 2007
    168
    london.
    One word. BRILLIANT.
  17. pterps
    pterps F1 Veteran
    Aug 18, 2006
    7,007
    Netherlands, Zwolle
    Peter
    Great thread Paul, I like the result sofar. Are there any shots of the car before you started this job?
    Peter
  18. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    Really impressive - Paul you are now threatening Dan's "Best All Time 348 Restoration" thread. Thanks for sharing your amazing work. Good luck with the rest.
    Troy
  19. fatbillybob
    Aug 10, 2002
    29,351
    socal
    Erine! You need to stop patching your 348 and take it all apart and rebuild it. Then it won't fall apart.
    Nice work Paul. What spring/shocks are you running? Is your package home brew or did someone test it?
  20. fatbillybob
    Aug 10, 2002
    29,351
    socal
    It looks like the 3 best 348's are in the UK?
    paul,
    sy,
    andy????
    I'm impressed with your guys love of the 348.
  21. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    +1
    This whole thing goes way beyond my imagination. What must a man do to be able to do a thing like this. :)
    Respect!
  22. Paul V
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
  23. Paul V
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    Sorry got no photos on file, i have a few paper photos that were taken by the garage that sold the car i will try and scan them.
    The car did not look to bad, yes it was a bit worn and tired but i have to admit to having the rose tinted Ferrari glasses on when i brought it. I brought it with my heart and not my head.
  24. Paul V
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    Hi there FB, the shocks are made by a UK company called "LEDA" and were made for me, i sent them the old shocks and they came up with this kit.
    It is one of the parts i hope will work out with out to much messing about, I should have gone with the guy who did Andy hills (i think SY is going to use the same guy) he was a bit more expensive but he had a tried and tested set up.
    As for being the best 348 in the UK, not so sure about that, both Andy’s car and SY car are quite special, i do want to put throttle bodies on it at some stage but have stopped myself doing it as i really need to get the car on the road.
    Thank you all for the nice comments it really does help me keep motivated with the project.
    All the best and i wish you all a good 2010
  25. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Excellent work!! And I just noticed this goes back 3 and half years!
