Work so far on my 348 | Page 6 | FerrariChat
Discussion in '348/355' started by Paul V, Mar 28, 2006.
  1. PAP 348
    Dec 10, 2005
    100,246
    Mount Isa, Australia
    Pap
    +1! :eek::eek:
    Oh yes, I remember that little car! :D:D
    Beautiful colour on it. :):)
  2. Dohangs
    Dohangs F1 Rookie
    3,129
    Florida
    Spiro
    Wow! What an amazing project you've undertaken. Keep up the good work.
  3. Harsh
    Harsh Rookie
    Nov 12, 2007
    1
    London
    Bachi Mehta
    Paul, that looks fantastic mate,
    I know al will do a great job of the paintwork for you as well.
    Cant wait to see it!
  4. PAP 348
    Dec 10, 2005
    100,246
    Pap
    Nice first post, welcome! :):)
  5. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,238
    Huntsville, AL., USA
    Andrew
    This thread is a great read. :D
    I'm still not sure what those things that look like wide shower heads are. Are they the pre-oil filters that were referred to?
    Wow... took over 2 years to make a first post from his join date. :eek: :D
    Good to see the lurkers coming out to play and - indeed - welcome! ;)
    All the best,
    Andrew.
  6. captglen
    captglen Formula 3
    1,790
    West Palm Beach, Fl
    Glenn L.
    Yes they are the pre Oil Filters
  7. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,238
    Andrew
    :) Thanks Glenn, what does a pre-oil filter actually do? Is it for preventing large fragments damaging the filters themselves? :confused:
    All the best,
    Andrew.
  8. ricardo teixeira
    ricardo teixeira Formula Junior
    Sep 2, 2009
    356
    Luanda / OPorto
    Ricardo Teixeira
    I believe that they are for stoping larger than normal debris to be sucked by the oil pump itself, damaging it..
  9. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,238
    Andrew
    Thanks Ricardo. :)
    All the best,
    Andrew.
  10. PAP 348
    Dec 10, 2005
    100,246
    Pap
    They are normally called filter screens. :):)
    Ricardo is correct. They are there to catch any large debris before it gets sucked into the oil pump. :):)
  11. MarkJ
    MarkJ Formula Junior
    Sep 10, 2006
    729
    NW Arkansas
    Mark Jones
    Paul, Do you think you'll get this on the road in 2010?
  12. Paul V
    Paul V Formula Junior
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    I do hope so Mark. I hope to have it done mid to late summer
  13. Paul V
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    #138 Paul V, Jan 15, 2010
    Just thought i would share some info on the tool i used for shimming the valve clearances.
    I have read about the tool but never seen it in use; i purchased it from T. Rutlands. As you can see in the photos you get 2 parts, i called them spoon and hook, they are both made out of brass.
    You push the spoon tool between the cam and the shim; there is notch in the shaft that sits on the head. Then install the hook around the bottom of the cam to keep the bucket pressed down, now remove the spoon and the valve should stop open. Blow some compress air into the slot on the bucket and the shim will “pop” out.
    One thing that came apparent was the brass “hook” was not going to last very long as the pressure from the valve spring was wearing the edge where is sits on the bucket, so a cut one out of some mild steel which has a much better feel to it and so far has not taken the edge off it.
    I had seen various threads on valve shimming and kept reading about the shims measuring a different thickness to what was stamped on them (I am talking new shims) go to say i took this with a pinch of salt how wrong was i !!! I ordered what i needed and most of them were out. Lucky with a bit of moving around i got 13 out of the 16 where i wanted them, but i had 3 shims that needed to be 3.70mm and they were 3.65 to 3.68mm.
    I rang up the supplier and asked if they could go and measure there 3.70mm shims for me, but the main man was on holiday so I said sod it send me 10 of them, got them today and out of the 10 3 were the right size!
    Hope you enjoy
    Regards Paul
  14. smallblk40
    smallblk40 Karting
    Nov 8, 2009
    73
    Phoenix, Arizona
    A.J.
    I'm new here...but all I wanted to say was OMG!!! what an amazing thread to follow & view. Thank you for bringing us all with you through this restoration!!! This car will be better then new once fully completed.
  15. MarkJ
    Sep 10, 2006
    729
    NW Arkansas
    Mark Jones
    Its a clever design and looks like it works quite well.
  16. Paul V
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    #141 Paul V, Jan 17, 2010
    Just a few more photos from today’s work.
    Finished building up the LH cylinder head, was time to reunite it with the block.
    New gasket, nuts, studs and torque up to 60nmn then turned though 90 deg.
    Fitted the freshly coated exhaust manifold again with brand new studs and nuts.
    Going to start to build up the RH cylinder head now, so expect to fit that next weekend.
    The last photo is to show the finished repair to the engine cradle.
  17. captglen
    captglen Formula 3
    1,790
    West Palm Beach, Fl
    Glenn L.
    Paul,
    Outstanding !!!!
  18. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,238
    Andrew
    That looks really nice. :cool:
    Hope the RH cylinder head goes smoothly. :)
    All the best,
    Andrew.
  19. jmiff348
    jmiff348 Formula 3
    2,369
    Texas, USA
    Jarrett
    Looks fantastic, Paul! Keep the pics coming!
  20. PAP 348
    Dec 10, 2005
    100,246
    Pap
    Awesome pics mate! :D:D
  21. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    That is Fantastic!!! Where did you get the exhaust manifold? I've never seen an aftermarket one for a 348. Sure is pretty compared to the one piece stock unit.
  22. MK348
    MK348 Rookie
    Jan 18, 2010
    3
    San Bernardino
    Great work, looks awesome!
  23. Philip Barnard-Browwn
    Feb 25, 2007
    168
    london.
    Philip Barnard-Brown
  24. Paul V
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    The manifold is the stock Ferrari one with the "tin" covers removed. I had it coated to keep the heat down.
    Thanks all for your positive comments
    Regards Paul
  25. PAP 348
    Dec 10, 2005
    100,246
    Pap
    Looks the goods and looks aftermarket with the tin heat shields removed. :eek::eek:
