Work so far on my 348 | Page 8 | FerrariChat
Discussion in '348/355' started by Paul V, Mar 28, 2006.
  1. Paul V
    Paul V Formula Junior
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    #176 Paul V, Apr 16, 2010
    More of update although I have already done all of this work some weeks ago I thought I would post the photos.
    When I removed the fuel tank there was something loose inside. Having seen Ernie thread on rebuilding the fuel pumps I decided to strip and rebuild both pumps (see photos) my pumps were nowhere near as bad as Ernie’s ones.
    I have a feel around in the tank and could feel there was a loose baffle that sits between the 2 pumps. I thought long and hard about it and decided to open up the tank and either remove the baffle or try and re attach it.
    As you can see by the photos I cut open the tank and re welded the baffle back in and then welded up the flap I had made. Now my alloy welding is not the best looking but I pressure tested it and got no leaks.
  2. Paul V
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    #177 Paul V, Apr 16, 2010
    Here are some photos of the engine built up. I always wanted to “test” the engine before I installed it in to the car. So I strapped it to the Motorcycle lifts I have here at work and set about pluming it in and wiring it up to run. As you can see by the photos it does not take much in the way of work to attach the oil tank, Rad etc. The only thing I had a bit of hard time with was working out the for the Ecu but got there in the end.
    The engine fired right up and ran very sweet. Here is a video I made of the motor running. You will have to forgive the quality of the sound as I used my phone to take the video.
    http://www.youtube.com/watch?v=69iWs3Tx0Y0
  3. BigTex
    79,408
    Houston, Texas
    Bubba
    Awesome video!
    Serpentine belt in all it's glory! LOL!
  4. PAP 348
    Dec 10, 2005
    100,244
    Mount Isa, Australia
    Pap
    Very cool!! :):)
  5. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    This is cool stuff - very nice Paul.
  6. chas-3
    chas-3 Formula 3
    1,281
    Colorado
    Chuck
    Wow! That engine sounds so sweet. You have really done a fantastic job on your car.
  7. Paul V
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    #182 Paul V, Oct 17, 2011
    Wow ! well over a year since i last posted, sorry for the delay from me.
    I moved house 2 years ago and have been busy renovating it which has taken up all my spare time.
    I got the car back from the body shop (Alsa Automotive) early on this year but like i said i have not had the time to work on it.
    Since the nights have been getting darker i have been able to spend some time on the car, rather than the house.
    Here are some photos from the body shop, i have since installed the fuel tank, rads, wiring, engine, suspension drive shafts etc just waiting on some parts to fit the brake callipers.
    Will post more photos when i remember to take my camera to the workshop.
  8. PAP 348
    Dec 10, 2005
    100,244
    Pap
    Bloody hell Paul, it's been a long time between drinks. :p:p
    Great pics, car looks like new.
    Please don't wait so long to update us with pics. ;)
    What is the next plan of attack?
  9. Paul V
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    #185 Paul V, Oct 17, 2011
    Thanks Pap, will try and keep this thread up to date now!
    The Plan
    Finish off installing the running gear and brakes, then start work on the interior refit, then road test of which i cannot wait for. Don’t know if you remember but i purchased the car early 2006 and have only driven it for around 100 miles!
    I have had the motor runing in the car and done a few “heat cycles” to make sure all the radiator fans work as they should.
    Dug out the gravel guards tonight and i can see there is going to be a few hours work brining them up to scratch.
    Here 2 photos (taken on my phone) putting the engine back in.
  10. chas-3
    chas-3 Formula 3
    1,281
    Colorado
    Chuck
    I was remembering this thread just the other day and was going to post asking if anyone knew what had happened to this project. Good to see the work continues. Keep it up Paul! :)
  11. Chupacabra
    Chupacabra F1 Rookie
    3,587
    Behind a drum kit
    Mr. Chupacabra
    Wow, this all got under way 5 years ago? Wow! Looking GOOD!
  12. Cavallino Aficionado
    Oct 3, 2006
    2,016
    Lk. Tapps/Buckley WA
    Brian
    Very exciting Paul. I know you're looking forward to the finish product much more than we are!! Everything looks great, top notch!! :) :)
  13. Organiser
    Organiser Formula Junior
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    Hi Paul,
    Looks like Al did a great job for you there!!
    Keep up the good work, I look forward to seeing the car when its finished.
    Regards,
    Phil.
  14. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    Nice update.
    This is what I need to do to my pile one of these years.
  15. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Great work, Paul...keep going ;)
  16. Paul V
    Jan 25, 2005
    324
    Shropshire (UK)
    Paul
    #192 Paul V, Oct 20, 2011
    Thanks Guys for the kind words.
    A small update (sorry for the poor photos taken on my phone)
    Got all the drive shaft and suspension on now and finally fitted the brake callipers once i got the shims from Ferrari. Why they could not get there machining right i don’t know ?
    Had to spend quite a bit of time to get the calliper centred on the disc but got there in the end.
    Got the wheels on and it sat under its own weight for the 1st time is 3 years, got the set the ride height and the rear camber next
  17. chas-3
    chas-3 Formula 3
    1,281
    Colorado
    Chuck
    Damn, that is so sweet!
  18. ernie
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    Landsakes man! You are spending a mint on that car. Did you get everything refinished because it looks brand new. That entire rear hub looks fantastic!
  19. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Terrific job, looks unreal
  20. PAP 348
    Dec 10, 2005
    100,244
    Pap
    Very cool Paul. Car is looking like new and it reminds me of another old Fchatters 348 (Dave I think his name was) with a 348 that was restored to like new. :D
  21. Organiser
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    Hi Pap,
    I think you mean Dale`s 348, not that he ever used it while he owned it!!
    Looking at Paul`s car, I have a feeling it could be the same, but I hope not?
    Regards,
    Phil.
  22. PAP 348
    Dec 10, 2005
    100,244
    Pap
    Hello Phil, YES!! Dale's car! :D
    Yeah, he never drove it and I don't blame him. :eek::eek:
    Hopefully Paul doesn't restore it to that level which may make the car "un-driveable". :)
  23. dertizjos
    dertizjos Formula Junior
    Jul 20, 2011
    453
    New Jersey
    Nothing like all that new stuff. The car looks amazing!!!!!
  24. Dohangs
    Dohangs F1 Rookie
    3,129
    Florida
    Spiro
    Looks amazing. Great job!
