Working on headlights. How to leave them up? | Page 3 | FerrariChat
Discussion in '348/355' started by bjwhite, Aug 20, 2017.
  1. bjwhite
    bjwhite F1 Rookie
    4,803
    Seattle, WA
    Brian White
    True, but stock or just slightly higher wattage on a proper beam pattern is fine. No need for 100W or crazy HID bulbs or anything silly like that.
  2. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Agreed.
    Probably one of the best things you can do is to make sure you're getting enough voltage to the bulbs (and rectify, if not). These are Italian cars after all with "aged" Italian wiring.
    Would love to see an LED version of the lamp assembly - I mean a version the same size and shape and mounting points but with the reflectors and glass designed/engineered for LEDs. I would buy those!
  3. m.stojanovic
    m.stojanovic F1 Rookie
    3,176
    Serbia - Niš
    Miroljub Stojanovic
    #53 m.stojanovic, Aug 26, 2017
  4. bjwhite
    bjwhite F1 Rookie
    4,803
    Seattle, WA
    Brian White
    Finally back home to continue this. Went around the world last week, literally. Seattle to Hong Kong, stayed 1 day. Hong Kong to Taiwan, 3 days. Taiwan to Mumbai, two days. Mumbai to London, one day. London to Seattle. :)
    Anyway, the loosening of the two bolts/nuts on the left headlight was very helpful. Gave just enough room to get the headlight out. The right side is much easier due to the mounting tab positions and I didn't need to loosen anything.
    Actual headlight configuration adjustment was just like what was posted elsewhere.
    I'll post comparison pics when it gets dark.
  5. bjwhite
    bjwhite F1 Rookie
    4,803
    Seattle, WA
    Brian White
    #55 bjwhite, Sep 4, 2017
    Ok, here are comparison pics. The top pic (LHT setup) you can see the slightly dimmer light from the right headlight. The bulb wasn't all the way in its socket and was sort of sticking out a little bit--like one notch wasn't set and the bulb wasn't flush. You can see how that affected the light output.
    Bottom pic, lights set up for RHT (LHD) and this bulb corrected.
    The car may have been a different distance slightly from the door. I didn't measure--but you get the idea.
  6. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Thanks for the photos - clearly shows the difference. Now don't forget to change the part numbers on your headlamps! :)
    Can the screws be loosened and the assembly rotated from below the car (can the assembly be rotated without removing the headlamps)?
  7. bjwhite
    bjwhite F1 Rookie
    4,803
    Seattle, WA
    Brian White
    In my opinion, no it can not. Then again, I didn't have it up on a lift looking at it from below.
