Would a Maserati variator solenoid fit a F430? | FerrariChat
Discussion in '360/430' started by Zed82, Nov 12, 2018.
  1. Zed82
    Zed82 Formula Junior
    Sep 28, 2017
    513
    Sweden
    whatheheck likes this.
  2. Fenz
    Fenz Karting
    Nov 8, 2018
    176
    Team Europe
    Send the seller a message and ask if they can guarantee that the cross-references between Maserati and Ferrari part number is correct.
    It would surprise me if Maserati/Ferrari would use different solenoids on different versions of the F136 engine.
  3. Zed82
    Sep 28, 2017
    513
    Sweden
    My thought too.
  4. Zed82
    Sep 28, 2017
    513
    Sweden
  5. Fenz
    Fenz Karting
    Nov 8, 2018
    176
    Team Europe
    Ok, let's wait and see if somebody else here got some valuable info about this topic.
    I'm curious too, not that my solenoids needs to be changed at this point, but for future reference :)
  6. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I looked into that as well and unable to get a definite answer......
  7. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,783
    The cables are different lengths - the Maserati part fits the F430 but not the other way around.
    brogenville, Zed82 and Fenz like this.
  8. Zed82
    Sep 28, 2017
    513
    Sweden
    Same function?
  9. Zed82
    Sep 28, 2017
    513
    Sweden
    They were not available last time I checked. And double the price.
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,968
    Isle of man- uk
    About £400 if available
  11. Zed82
    Sep 28, 2017
    513
    Sweden
    Bringing up an old topic again. Are you sure the Maserati part has the same function if installed in an F430? @mwstewart
  12. vrsurgeon
    vrsurgeon F1 World Champ
    16,552
    Charleston, SC
    Curt
    The solenoid just opens and closes. If opening diameters are the same and it allows oil to flow at the same rate then should work. OTOH the key issue imho is the resistance of the coil in the solenoid. If it matches then should work.. if it doesn’t it will throw codes
  13. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,783
    I haven't tried them, but next time my car needs a set I will do.
    Zed82 likes this.
  14. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,783
    f355spider, whatheheck and Zed82 like this.
  15. Zed82
    Sep 28, 2017
    513
    Sweden
  16. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    mwstewart likes this.
  17. 430driver
    430driver Rookie
    Feb 5, 2017
    7
    LONDON
    Chris Tomas
  18. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,783
    Yep - absolutely fine.
    Denzel Yang and brogenville like this.
  19. 430driver
    430driver Rookie
    Feb 5, 2017
    7
    LONDON
    Chris Tomas
    Thanks Mark have ordered 4 of 212423 variations control solenoid coming from Italy Eurospares Approx 14 days to arrive
    Will let you know how I got on then
    Thanks for the information
    Regards
    Chris
  20. 24000rpm
    24000rpm F1 Rookie
    I wonder if 599 gto's variable timing solenoid(296016) fits the 430.
    The reason for the guess is that the 599 GTB's solenoid is have the same part # as the 430. So GTO's shouldn't be too far off?
    I understand the connector could be different but shouldn't that be an easy DIY modification?
    the price of 296016 is only 1/5 of the price of the 212423 or 250646
  21. RichardCH
    RichardCH F1 Rookie
    4,661
    any updates on this thread pls ? if the variator solenoid fails it generates a CEL right ?
  22. FLA_997
    FLA_997 Rookie
    Oct 12, 2017
    10
    Orlando, FL
    Greg Fiore
    Old thread but the 296016 appears to be very different. I'm ordering 4 of the 212423 Maserati solenoids for mine now.... I found the for $423 a piece.
