Wt. of oil | FerrariChat
Wt. of oil
Discussion in 'Technical Q&A' started by Robb195512, Jun 24, 2010.
  1. Robb195512
    Robb195512 Rookie
    Aug 16, 2009
    16
    I know that Porsche runs Mobil 1 0w40 in their GT2 and GT3's. Is it acceptable to run it in a 2009 Scuderia
  2. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    I would think so. However, my dealer told me they get mobil1 5-40 from the Mercedes dealer. It is not sold in stores. They don't like Shell because of the foaming issues.
    Dave
    PS: I've been using 0-40 in my 328 for many years. The manual called for 10-40.
  3. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I just bought 2 qts of Castrol syntech 5-40 at Autozone for my kids Audi. $7 a qt.
  4. BIGHORN
    BIGHORN In Memoriam
    Sep 18, 2006
    733
    FLORIDA/NEW MEXICO
    JOHN F KELLY
    I would stick to mfg's recommedation
  5. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,734
    Depends on the purposes the car will be put through with this oil in the sump.
    For less than race track use*: yes, 0W-40 is essentually interchangibel with 5W-40 and 10W-40. {Oil temperatures below 250dF}
    For race track use you really want an oil with a high HTHS number. M1 0W-40 has a rather anemic 3.7 cP HTHS while Redline 10W-30 has 3.8 cP HTHS, and RedLine 10W-40 has 4.6 cP. M1 5W-40 TDT has 4.2 cP.
  6. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,858
    Atlanta
    John!
    If going 250+ temps, one might want to get into an 50w synthetic from Redline or the like. Perhaps even 60w Shell helix racing a la Enzo or Jim's racing Dino engine. 40w synt with a high HTHS is perfect for anything else though. Great flow and protection from starting viscocity temps etc.
  7. NORTY
    NORTY Formula Junior
    Aug 15, 2008
    562
    CARLSBAD, CA, USA,
    NORTY
    Dave, you got any info regarding the "foaming issues" with Shell? I'm interested in this.
  8. hardtop
    Jan 31, 2002
    11,294
    Colorado
    Dave
    I know it's been duscussed here sometime but basically when you check your oil and open the reservoir, you will see a lot of foam so theoretically, it is foaming inside the motor as well. I'm sure it does no harm except maybe reduce power a little. More of pain than anything else. When my 430 went out of warranty, I suggested to my dealer to switch to mobil 1 and they told me they had been using it all along. I know some 430s do use some oil but mine never used a drop. Perhaps the Shell oil burms off more also but that is speculation on my part.
    Dave
  9. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,324
    What does the manufacturer spec call for? If its a 50 weight oil then that's what you should use beause a 40 will be too thin at the upper end of the engine's operating temperature range.
    In practise Mobil1 has a very wide operating range but none the less if you had a problem & then were found to have the wrong weight/spec of oil in the car........
