WTf? | FerrariChat
WTf?
Discussion in '348/355' started by albert328gts, Aug 2, 2008.
  1. albert328gts
    albert328gts Formula 3
    1,667
    California
    Picked up my car, it had a "new" alternator put in, not easy to find. Car runs great, strong and fast. But going up the rpms, when I get to 5K or there about, the tach starts to dance up and down? WTF? Mechanicaly nothing else is happening? Confused???
  2. PAP 348
    Dec 10, 2005
    100,228
    Mount Isa, Australia
    Pap
    #2 PAP 348, Aug 2, 2008
    Possible bad ground I reckon. Check the ground from the battery to the engine cradle. :):)
  3. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,974
    MD and NE
    Robbie
    Tach problem? Sender? The car itself goes up in the Rs ok? No hesitation?
  4. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Relax, it's not that. Probably he sender. Or a bad connection or ground.
  5. albert328gts
    1,667
    California
    Wow quick answers, always amazes me. I will look into the ground or sender. The car runs fine. No hesitation.
  6. Llenroc
    Llenroc F1 Veteran
    5,549
    Colorado
    Vern
    Check the condition of the battery.
  7. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    My money is on your “new” alternator not charging the system.
    One of the basic charging system diagnoses is a fluctuating / bouncing tach at higher revs. The reason is that as the revs go up a greater demand is placed on the battery so the voltage drops and the tach is the more sensitive to voltage drops than the ignition system.
  8. albert328gts
    1,667
    California
    Battery is a 6 month old optima, so not the battery? They checked it out, it was a in good condition..
    Worried about ferraridriver comment on the "new" alternator.
  9. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    For what it’s worth, I’ve seen this many times in the past, it’s always been the alternator.
    Until you diagnose the problem properly I wouldn’t trust it to drive, at least not without your AAA card. If it’s really the alternator the battery will eventually give out and leave you stranded.
  10. f355spider
    f355spider F1 World Champ
    18,054
    Is the new alternator properly grounded, with a ground strap from the alternator to the oil sump?
  11. Doc Bob
    Doc Bob Karting
    Apr 18, 2008
    66
    Dubai, UAE
    Dr. Robert Read
    #11 Doc Bob, Aug 4, 2008
    Ah yes.......the old "alternator bad-from-the-box trick" again. Maybe this is your problem as well but I would check the ground strap from the alternator first. The stealerships and their supposedly "factory trained" grease monkeys often forget to put it back on. Ever wonder what they do with those pieces they find remaining after you have driven away in your car? "Re-sale, re-sale!" On the other hand, I just went through a "bad-out-of-the-box" episode with one of those wonderful gold-plated-stick-it-to-you Ferrari masterpiece alternators. Put the thing on the car and it put out a whopping, almost constant 12.7 volts. Not so bad for a generator off of a 1952 International tractor!!!!
    Threw it (literally) back into the lovely Ferrari show piece box and took it to the local alternator repair shop and when we bench tested it we found TONS wrong with it. Both the rectifier AND voltage regulator were screwed. Not to the point of not functioning but to the point where you could never run it and hope to go to 7-11 three blocks down the freaking street. Pathetic to say the least.
    AND THIS IS WHAT WE PAY FOR?!?!?!?!
    Living in the Middle East has its disadvantages when you have to return something back to the Mothership. It is infuriating, the number of parts that are questionable at best from Ferrari. However, living in the Middle East does have one advantage in that necessity is truly the mother of invention and with the help of Google invention turns out to be a more reliable Ferrari with better parts at 1/5 the price! Even things like fuel and oil filters. Wanna know who makes those and where to buy them??????? Google baby, Google.
    I'm tired of lining the pockets of Italian shareholders who, if they didn't dominate F1, wouldn't even HAVE an automobile that is marketable let alone reliable. KIA is more reliable. Maybe even Skoda. Don't get me started on the "oh but Ferrari is much more complex automobile." This is a cover up, catch-all, Maranello Manure statement from those that have never taken one apart! And for all of us that have taken them apart, I guess we scratch our heads, have another sip of beer and say "Good thing it looks good!" :)
  12. albert328gts
    1,667
    California
    Took the car to the shop that did the work, ran great, except for the ever bouncing tach. They took it for a drive, and saw that too, looked at the ground and all looked good. Then put the car back on all 4 wheels and started it, or rather TRY to start it, battery was dead, never got a warning light or anything, said they would make good on the alternator. I cant believe it, I picked it up on Friday, drove it home, drove it for about an hour on Saturday and stopped when I saw the ever bouncing tach, then 15 minutes today to the shop and the alternator is for ****. Ferrari parts suck! No ****, even if they are Delco or Nippon alternators, they all suck!
  13. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    Hi Albert,
    Sorry to hear about your electrical gremlins. But believe it or not, the clouds have parted - and they reveal this silver lining - http://emelbon.tripod.com/eugeniosferrariservice.html
    Eugenio is a Ferrari angel. He will prevail. He will find the gremlin and remove it from your car. Your zip code makes this very doable - your time frame may be an issue though honestly, don't let it be one. Call E and talk.
    Dat's all I can say - -
    Cheers, Hank
  14. f355spider
    18,054
    #14 f355spider, Aug 5, 2008
    Another solution found for some of these gremilins is to check that the "S" wire which connects on the positive terminal (clamp) at the battery. Apprently this red wire (14 gauge or so) is molded into the lead clamp itself, and can fray or break off from the clamp causing problems. Worth checking. Also clean and check all the connections at the terminal block under the right side engine cover plate (passenger side).
    These tips may help also:
    http://www.ferrarichat.com/forum/showpost.php?p=137803385&postcount=3
  15. Doc Bob
    Doc Bob Karting
    Apr 18, 2008
    66
    Dubai, UAE
    Dr. Robert Read
    Ah yes!!!!!!!!!!!!!!! Good catch on the battery wire issue. I drove myself nuts for an entire weekend and then noticed that discreetly the wire had corroded and parted ways with its little lead buddy. A divorce of sorts brought on by time.........just like all the rest I reckon. Check that puppy! Reattach and run! simple.
  16. Fpassion
    Fpassion Formula Junior
    Jun 1, 2005
    599
    Bad part or they connected two wires backwards causing a load. If they replace the alternator the problem persists look for operator error on wires.
