X-37B ? what kind of fuel are they filling it with? | FerrariChat
Discussion in 'Aviation Chat' started by Ryan S., Jul 26, 2012.
  1. Ryan S.
    Ryan S. Two Time F1 World Champ
    28,901
    #1 Ryan S., Jul 26, 2012
  2. Ryan S.
    28,901
    just read this on wiki....
    In 2011, Boeing announced plans for a scaled-up variant of the X-37B, referring to the spacecraft as the X-37C. The size of the X-37C would be approximately 165 to 180% of the X-37B, allowing it to transport up to six astronauts inside a pressurized compartment housed in the cargo bay. The X-37C's proposed launch vehicle is the Atlas V Evolved Expendable Launch Vehicle.[54] X-37C may compete with Boeing's CST-100 commercial space capsule.[55]
  3. Ryan S.
    28,901
    Edit: Think found answer to my ?
    "Hydrazine (also called diazane) is an inorganic compound with the formula N2H4. It is a colourless flammable liquid with an ammonia-like odor. Hydrazine is highly toxic and dangerously unstable unless handled in solution. As of 2002, approximately 260,000 tons were manufactured annually.[5] Hydrazine is mainly used as a foaming agent in preparing polymer foams, but significant applications also include its uses as a precursor to polymerization catalysts and pharmaceuticals. Additionally, hydrazine is used in various rocket fuels and to prepare the gas precursors used in air bags. Hydrazine is used within both nuclear and conventional electrical power plant steam cycles to control concentrations of dissolved oxygen in an effort to reduce corrosion."
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    UDMH (hydrazine) and Nitrogen Tetroxide have been widely used as propellants since the 50s.
    They are both highly toxic and ignite on contact with each other (hypergolic). Fueling a vehicle with that stuff is scary business.
  5. MarkPDX
    MarkPDX F1 World Champ
    Apr 21, 2003
    15,111
    Gulf Coast
    That picture looks like an after landing shot so it's doubtful that any fuel is going in. If I were to guess I bet that is blowing cool air into the thing to keep electronics from cooking once it has landed, probably supplies it with power as well since I don't see any other external power source. My guess is that it lands and whatever onboard power generation and cooling system shuts down and they start doing post flight stuff.... Everything is still heat soaked so they hook up an A/C cart to keep things from overheating.
    Find some pics of the Space Shuttle after landing and I beT you will find them hooking up something similar.
    Hydrazine is nasty stuff but it's about as close as you can get to a "sure thing" when you need a power source.
  6. Ryan S.
    28,901
    #6 Ryan S., Jul 26, 2012
    Why the need for the suits if fuel is possibly spent? Seem to wear em in all the shots. Seems like they may be drying the tanks in some way?
  7. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,421
    SFPD
    Dirty Harry
    There's vapor . . . and then there's vapor.
  8. Ryan S.
    28,901
  9. MarkPDX
    Apr 21, 2003
    15,111
    Gulf Coast
    Hydrazine (and other rocket fuels) are some really nasty stuff. If there is even a little whiff of vapor you are f cked. They do the same thing around the Space Shuttle when it lands.
    The F-16 uses hydrazine to power it's emergency APU and if one crashes they will clear out a pretty significant area around the crash scene.
  10. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Reminds me of the 1944, ME-163 Komet which used hydrazine hydrate and methanol, designated C-Stoff, that burned with the oxygen-rich exhaust from the T-Stoff, used as the oxidizer.
    The fuel system was particularly troublesome, as leaks experienced during hard landings easily caused fires and explosions. Metal fuel lines and fittings, which failed in unpredictable ways, were used as this was the best technology available. Both fuel and oxidizer were toxic and required extreme care when loading in the aircraft, yet there were occasions when Komets exploded on the tarmac from the propellants' hypergolic nature. The corrosive nature of the liquids, especially for the T-Stoff oxidizer, required special protective gear for the pilots.
    Nasty stuff.
    I would be wearing a suit too.
  11. TooTall
    TooTall Karting
    Sep 15, 2006
    179
    So Cal
    Kurt O.
    Back in the '60s the Top Fuel dragster guys would add some hydrazine to the fuel mix. Illegal, yes. Dangerous, completely. The hydrazine would give the exhaust flames a green tinge. There was even a little saying. "If it's burnin' green he's runnin' hydrazine". made for some mighty impressive engine explosions also.
    Kurt O.
  12. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #12 2NA, Jul 28, 2012
    I've used 90% hydrogen peroxide as rocket fuel quite a bit. I never wore a space suit when working with it but was careful about handling it due to its reactive nature. Clothing was typically polyester (cotton would ignite on contact) and plenty of water was kept around to dilute any spills. Contact with the skin would result in uncomfortable tiny white blisters that would disappear after a while. I was always careful to wear a face shield as contact with the eyes could be a problem.
    There was a dragster built that did utilize hydrazine and NTO for propellants. It was Craig Breedlove's "Screaming Yellow Zonkers" car. It was built as a prototype and test vehicle for a planned LSR car using the same technology. The rocket motor was similar to that used by NASA on the Lunar Module. I never had the pleasure of seeing it run but from the accounts that I've heard over the years from the guys that built and took care of it on the road, it was scary business. Fuel and oxidizer were carried on separate trucks. During fueling they were parked on opposite sides of the car some distance away. Lots of concern about the possibility of an accident. During the run the car made a 40 foot flame and an absolutely ear-splitting roar. One photographer attempted to get the shot-of-a-lifetime from the business end and was nearly incinerated. He was persuaded to trigger his camera remotely, it was never seen again! This car was easily the most terrifying thing to ever go down a dragstrip.
    Breedlove, who is no stranger to risk-taking and pushing the envelope, allegedly had a recurring dream of dying in the car and stopped running it. He abandoned the rocket technology and went back to what he knew, jet engines.
  13. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    #13 Spasso, Jul 28, 2012
    I saw a hydrogen peroxide dragster run similar to this one back in the 70's.
    In total silence two guys push it to the staging area, one quick blip to prime and then GONE!
    None of the drama and excitement of a jet car.
    Still, impressive performance. Better than a jet by far.
  14. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The Pollution Packer was built by my friend Ky Michaelson from his former Top Gas car. This car was the first to break 5 seconds, 4 seconds and 300 miles per hour in the quarter mile. Dave Anderson drove it to a World Record 344 mph in 4.62 seconds at the US Nationals at Indy in 1973. Dave was killed in a crash at Charlotte Motor Speedway running on an 1/8 mile track thru the infield in March of 1974. His was the first of several fatal crashes that brought the end to rocket car racing.
  15. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Awesome to watch.
    Sorry about the results.
  16. dmaxx3500
    dmaxx3500 Formula 3
    1,027
    jet and rocket cars were the coolest thing,i saw many at ''great lakes dragway,with broodway bob''
  17. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #17 2NA, Jul 28, 2012
  18. dmaxx3500
    dmaxx3500 Formula 3
    1,027
    sad,damed shame,he was a trip ,we would see him all the time in the 70-80's at the ''grove'',he allways had a beer in his hand
