Xm no signal | FerrariChat
Xm no signal
Discussion in '612/599' started by icelander47, Sep 28, 2018.
  1. icelander47
    icelander47 Karting
    Sep 12, 2012
    142
    Trying to setup xm in my 08 and on channel 1 it says no signal. Have tried to have the signal resent twice. I don't see an antenna hump on the trunk so not sure where the antenna is.
    Any ideas?
  2. F612
    F612 Formula Junior
    Feb 5, 2018
    643
    Leeds,AL
    David D. Hood
    I can see the antenna in your picture
    It is the little hump behind the rear glass
    Check the wiring and the fuse
  3. icelander47
    icelander47 Karting
    Sep 12, 2012
    142
    It was what someone else posted, the wire broke. Ferrari used solid instead of flexible wire and it snapped. Thanks to La Jolla audio all solved
  4. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    I have the same issue...where does the wire typically snap ? Appreciate any advice .
  5. donv
    donv Two Time F1 World Champ
    26,264
    Portland, Oregon
    Don
    On the 612, the antenna is on the trunk lid and the repeated opening and closing of the trunk wears the wire out. Mine did the same thing recently.
